  • Mikael Axel Kleinwort 154 posts 499 karma points c-trib
    Apr 05, 2020 @ 11:16
    Order of inherited DocType property groups not honored
    In Umbraco 8.6, I have a DocType structure like this
    Level1DocType -> Level2DocType-> Level3DocType
    so Level1DocType inherits from Level2DocType, which in turn inherits from Level3DocType.
    Each DocType adds one group of properties. In content items of type Level3DocType, I want the groups to show up in this order:
    Intended Group Order:
    • Level3DocTypeGroup
    • Level2DocTypeGroup
    • Level1DocTypeGroup
    So in the DocType editor for Level2DocType, I have reordered the groups so Level2DocTypeGroup is first, followed by Level1DocTypeGroup inherited from Level1DocType:
    Expected order of inherited groups:
    but in the DocType editor for Level3DocType, the inherited groups show up in the order of inheritance and not in the order specified in Level2DocType:
    Actual order of inherited groups:
    so there is something not working right here.
    For Level3DocType, I now have this group order:
    • Level1DocTypeGroup (inherited)
    • Level2DocTypeGroup (inherited)
    Now if I create a content item of type Level3DocType, the content item has the following order of property groups:
    Actual group order of content item:
    Expected group order of content item:
    So it seems that when inheritance of DocTypes is in play, the group order as defined in the DocType is not honored.
    Am I doing something wrong, or is this an issue which I should add in the issue tracker?
    Thank you for any input on this!
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Apr 06, 2020 @ 07:22
    Steve Morgan
    If you go into the sorting on each doctype and manually enter a sort number (don't try to drag the groups - enter the number).
    I tend to space in 10s (so doctype 3 = 0, doc type 2 = 10, doc type 1 = 20) then does that resolve it?
    Apr 06, 2020 @ 20:21
    Hello Steve,
    thank you, this does the trick!
