  • Aleksandar Herman 4 posts 74 karma points
    Apr 07, 2020 @ 17:55
    Aleksandar Herman
    Run Umbraco locally problem
    Greetings everyone,
    I have worked on Umbraco project on my own, and later it was uploaded on web server.
    Now I've got to make some changes and I got back WWWROOT folder of my project (without .sln or project specific files).
    I have trouble running this project locally, I tried to upload it to my IIS server by creating new website and linking the project directory to it. Also I restored the database locally to my local SQL Server, and linked it in Web.config configuration file.
    I tried variety of solutions on the internet, by adding permissions to IIS_IUSRS, NETWORK SERVICE and all other users to full control, setting application pool identity to my local username and password (tested connection and both passed), .NET CLR version is 4, and so on.
    And when I open the page I get this:
    Error screenshot
    Does someone have a solution to this?
    Thanks in advance!
  • Yakov Lebski 594 posts 2350 karma points
    Apr 07, 2020 @ 21:09
    Yakov Lebski
    please check that pool is assigned for .net 4
    Apr 08, 2020 @ 20:10
    Aleksandar Herman
    Unfortunately, it is already set like that
  • Tim Miller 32 posts 252 karma points
    Apr 08, 2020 @ 21:10
    Tim Miller
    This is the sort of error you get if there is a problem with the XML in your Web.config file. If you updated your connection string you might start there.
    Apr 17, 2020 @ 21:06
    Alex Skrypnyk
    Hi Aleksandar
    Check please that IIS Rewriting module is installed on the machine.
    And check that files and folders permissions are set correctly, like described here - https://our.umbraco.com/documentation/getting-started/setup/server-setup/permissions
    Alex
