  • Nadia 45 posts 122 karma points
    Apr 09, 2020 @ 02:18
    Nadia
    SQL Connection errors
    I have a site that is on latest 7.15.4 it is a couple of years old so gone through several generations of upgrades.
    Also runs merchello. It is a reasonably busy site as well and hosted in azure.
    I am struggling to track down the cause, would anyone have any suggestions on where to look?
    I am getting one of these 2 errors complaining about the sql connection connection or timing out.
    System.InvalidOperationException: ExecuteReader requires an open and available Connection. The connection's current state is open. at System.Data.SqlClient.SqlConnection.GetOpenConnection(String method)
    at System.Data.SqlClient.SqlConnection.ValidateConnectionForExecute(String method, SqlCommand command) at System.Data.SqlClient.SqlCommand.ValidateCommand(String method, Boolean async) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior) at System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior)
    at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteDbDataReader(CommandBehavior behavior) at System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior)
    at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteDbDataReader(CommandBehavior behavior) at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
    at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClass5_0.<ExecuteReaderWithRetry>b__0() at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func
    1 func) at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteReaderWithRetry(IDbCommand command, RetryPolicy cmdRetryPolicy, RetryPolicy conRetryPolicy) at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteReaderWithRetry(IDbCommand command, RetryPolicy retryPolicy) at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteReaderWithRetry(IDbCommand command) at Umbraco.Core.Persistence.Database.
    System.Data.SqlClient.SqlException (0x80131904): Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding. ---> System.ComponentModel.Win32Exception (0x80004005): The wait operation timed out at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.getMetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior) at System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior)
    at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>cDisplayClass5
    0.
  • muhammad 5 posts 74 karma points
    Oct 05, 2020 @ 14:21
    muhammad
    Hi did you reach something about this? I'm trapped also.
    Oct 05, 2020 @ 16:18
    muhammad
    With reference to this
    The below should work
    And supported in async as well.
    var repositoryFactory = new RepositoryFactory();
    IScopeUnitOfWorkProvider uowProvider = new etaPocoUnitOfWorkProvider();
    using (var uow = uowProvider.GetUnitOfWork(readOnly: true))
        using (var repository = repositoryFactory.CreateContentRepository(uow))
            var x = repository.GetAll(guids);
    Oct 05, 2020 @ 18:42
    Nadia
    No, I think I scaled the DB up so allowed more connections
