var items = Model.MyNestedContentProperty as IEnumerable<PublishedElementModel>;
@Html.Partial("inPageNav", items);
throws
Cannot bind source type Umbraco.Web.PublishedModels.NestedContent to
model type
System.Collections.Generic.IEnumerable`1[[Umbraco.Core.Models.PublishedContent.PublishedElementModel,
Umbraco.Core, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null]].
Defining the view instead as
@model IEnumerable<PublishedElementModel>
throws
The model item passed into the dictionary is of type
'Umbraco.Web.PublishedModels.NestedContent', but this dictionary
requires a model item of type
'System.Collections.Generic.IEnumerable`1[Umbraco.Core.Models.PublishedContent.PublishedElementModel]'.
I know that I don't really understand how it is supposed to work. I am grateful for some hints in the right direction. Thank you!
And from your code, I can see that the error is throwing because of Passing Model and binding models are different.
Cannot bind source type Umbraco.Web.PublishedModels.NestedContent to model type System.Collections.Generic.IEnumerable1[[Umbraco.Core.Models.PublishedContent.PublishedElementModel]].
Please use the same Model for both passing and binding
IF the above is not working, please use the dynamic way
I however would like to share a version which uses a bit more code, as I had issues with doing it using your inline version. Maybe other developers will also get the same issues as me and could use this version.
var viewData = new ViewDataDictionary(ViewData);
viewData.Add("parameter1", parameter1);
@Html.Partial("PartialView", Model, viewData)
I did the creation of viewData in a code block
I used the PartialView name, not including the .cshtml extention
Simple way to pass parameter to partial view with Umbraco 8
What's the simplest way to pass a parameter to a partial view in Umbraco 8 ? I am (still) inexperienced with MVC and I am grateful for some insight.
I want to pass a
IEnumerable<PublishedElementModel>parameter (the value of a a nested content property) to a partial view.Using Macro Partials doesn't work out of the box.
IEnumerable<PublishedElementModel>is not available as a macro parameter type.This is my view definition:
the model type
NestedContenthas a nested content propertyMyNestedContentProperty.With the partial view
inPageNavdefined ascalling the partial like
throws
throws
Hey Mikael, You can simply pass the Model to a Partial View
1)
2)
Please see here for more info
https://our.umbraco.com/Documentation/Reference/Templating/Mvc/partial-views
https://www.jondjones.com/learn-umbraco-cms/umbraco-7-tutorials/umbraco-and-mvc/how-to-use-mvc-partials-in-umbraco/
Cannot bind source type Umbraco.Web.PublishedModels.NestedContent to model type System.Collections.Generic.IEnumerable1[[Umbraco.Core.Models.PublishedContent.PublishedElementModel]].Please use the same Model for both passing and binding
here
Danesh,
thank you for your answer. Now I get it :-)
I was thinking too complicated. I got it working in no time thanks to your advice.
Very cool. Mikael
You can also pass parameters in a ViewDataDictionary like this:
Here I'm passing the Model, and 2 parameters into the PartialView.
In the PartialView you can then do like this to access the parameters:
@sebastiandammark this post has helped me a great deal. Thank you for sharing!
Always ready with a great answer, Sebastian :-)
viewDatain a code blockPartialViewname, not including the.cshtmlextentionSame problem but now for Umbraco 13:
