  • Claushingebjerg 939 posts 2574 karma points
    Apr 14, 2020 @ 17:33
    Claushingebjerg
    multi url picker in 8.6
    So im trying to use the MUP in a navigation to let the editor add external links to a nav. I have the nav in a partial.
    Im basically doing this:
    @using Umbraco.Web
    @foreach (var item in menuPages) {
      var myLink = item.Value<Link>("theLink");
      @if (myLink != null)
           <a href="myLink.Url">@item.Name</a>
          } else {
           <a href="@item.Url">@item.Name</a>
    but it doesn't work. Doing "item.Value("theLink")" without returns the error "cannot convert from 'method group' to 'HelperResult'"
    Apr 14, 2020 @ 17:46
    Alex Skrypnyk
    How many items do you have selected in the MUP? If you have selected few items use this code -
    var links = Model.Value<IEnumerable<Link>>("footerLinks");
    If Max number of items is configured to 1
    var link = Model.Value<Link>("link");
    There is a difference in one or few Links
    Alex
    Apr 14, 2020 @ 18:03
    Claushingebjerg
    Apr 14, 2020 @ 18:10
    Alex Skrypnyk
    Maybe the issue is in this piece of code? =
          } else {
    probably it should be:
           <a href="@myLink.Url">@item.Name</a>
    Apr 14, 2020 @ 18:16
    Claushingebjerg
    hehe yeah, that would fix the href for sure :)
    The problem is it never gets that far, as the if statement "@if (myLink != null)" is never true. Even if links are defined...
    Apr 14, 2020 @ 18:28
    Alex Skrypnyk
    There are only 2 things that can be wrong - property alias "theLink" or the type "Link"
    Can you check both?
    And if all of these are correct - then I would recommend you to debug the code and check what value exactly is stored in item.Value("theLink")?
    Apr 14, 2020 @ 18:42
    Claushingebjerg
    "item.Value("theLink")" returns "Umbraco.Web.Models.Link"
    Please note that im using "@using Umbraco.Web" where the documentation uses "@using Umbraco.Web.Models"
    Apr 14, 2020 @ 19:57
    Alex Skrypnyk
    Try this code:
    item.Value<Umbraco.Web.Models.Link>
    Apr 15, 2020 @ 05:43
    Claushingebjerg
    SUCCES! thanks a lot.
