  • Andrew Unger 45 posts 148 karma points
    Apr 14, 2020 @ 18:27
    Andrew Unger
    Problem rendering multi media picker in version 7.2.8
    I am having problems rendering images with the multi media picker. I'm using version 7.2.8 which is a little older than I'm used to and I noticed I need to use 'umbraco:Macro runat="server" language="cshtml"' outside the razor call. For some reason "/umbraco:Macro" part of that tag is highlighted red so I know I'm doing something wrong. Here is what I have tried along with different variations.
                        <umbraco:Macro runat="server" language="cshtml">
                            var typedMultiMediaPicker = Model.Value<IEnumerable<IPublishedContent>>("largeCarousel");
                            foreach (var item in typedMultiMediaPicker)
                                <div class="carousel-item"><img src="@item.Url" alt="image3" class="image imageLarger" align="bottom"></div>
                        </umbraco:Macro>
    Apr 14, 2020 @ 20:07
    Alex Skrypnyk
    Hi Andrew,
    I think in version 7.2.8 Model.Value<>
    Probably it should be:
    var calouselMediaIds = UmbracoHelper.AssignedContentItem.GetPropertyValue<IEnumerable<int>>("largeCarousel");
    In this array, you will have an array with ids.
    Then You can get image with this code:
    foreach (var mediaId in calouselMediaIds)
    var mediaItem = Umbraco.TypedMedia(mediaId);
      <div class="carousel-item"><img src="@mediaItem.Url" alt="image3" class="image imageLarger" align="bottom"></div>
    Alex
    Apr 15, 2020 @ 12:12
    Andrew Unger
    Thank you for the help I tried using this method and I get this error. Do I need a certain using statement for this to work?
    Apr 15, 2020 @ 12:41
    Alex Skrypnyk
    Try to use just Umbraco instead UmbracoHelper, like this:
    var calouselMediaIds = Umbraco.AssignedContentItem.GetPropertyValue<IEnumerable<int>>("largeCarousel");
    Apr 15, 2020 @ 12:51
    Andrew Unger
    Thank you for your quick response that did not work either I get this error now "CS0234: The type or namespace name 'AssignedContentItem' does not exist in the namespace 'Umbraco' (are you missing an assembly reference?)" enter image description here
    Apr 15, 2020 @ 12:54
    Alex Skrypnyk
    Umbraco should not be a namespace. Can you show me all your code?
    Apr 15, 2020 @ 12:58
    Andrew Unger
        <!doctype html>
        <html>
        <head>
        <meta charset="UTF-8">
            <meta http-equiv="x-ua-compatible" content="ie=edge">
            <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, minimum-scale=1.0, user-scalable=no">
        <title>S ID</title>
                <link href="https://fonts.googleapis.com/icon?family=Material+Icons" rel="stylesheet">
                <link href="https://fonts.googleapis.com/css?family=Roboto:300,400,500,700" rel="stylesheet">
                <script src="js/jquery-3.2.1.min.js"></script>
            <script src="https://cdnjs.cloudflare.com/ajax/libs/materialize/1.0.0/js/materialize.min.js"></script>
                <link rel="stylesheet" href="css/materialize.css">
                <link rel="stylesheet" href="css/styles.css">
           <link href="https://fonts.googleapis.com/css?family=Roboto&display=swap" rel="stylesheet">
        </head>
        <body>
                <div class="container"><div class="row">
                    <div class="col s12 m12 l8 largerHeight">
                        <div class="float-left">
                                        if (Model.HasValue("logo"))
                                            <img src="@Model.MediaById(@Model.logo).umbracoFile" />
                                </umbraco:Macro>
                        <div class="cropped">
                                </umbraco:Macro>
                    <div class="col s12 m12 l4 smallerHeight">
                        <div class="cropped2 croppedUp">
                            <div class="carousel-item active" style="z-index: 0; opacity: 1; visibility: visible; transform: translateX(-43px) translateY(0px) translateX(0px) translateX(0px) translateZ(0px);"><img src="images/image1.jpg" alt="image" class="image"></div>
                            <div class="carousel-item" style="transform: translateX(-43px) translateY(0px) translateX(-418px) translateZ(-200px); z-index: -1; opacity: 0; visibility: visible;"><img src="images/image2.jpg" alt="image" class="image"></div>
                        <div class="cropped2 cropped3">
                            <div class="carousel-item" style="z-index: -1; opacity: 0; visibility: visible; transform: translateX(-43.5px) translateY(-7px) translateX(-441px) translateZ(-200px);"><img src="images/image2.jpg" alt="image" class="image"></div>
                            <div class="carousel-item active" style="transform: translateX(-43.5px) translateY(-7px) translateX(0px) translateX(0px) translateZ(0px); z-index: 0; opacity: 1; visibility: visible;"><img src="images/image1.jpg" alt="image" class="image"></div>
        </body>
        </html>
    Apr 15, 2020 @ 13:04
    Alex Skrypnyk
    What about first line? it looks like missing @inherits section
    Apr 15, 2020 @ 13:15
    Andrew Unger
    I'm not sure what inherits I would need. All the other pages on this site don't use any. They do use this <%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %> but I think that is just for the nav, but this page doesn't use that because it's its own thing and not part of the main website
    Apr 15, 2020 @ 13:20
    Alex Skrypnyk
    Ah, so you use WinForms solution, not a razor, it changes the game
    Apr 15, 2020 @ 13:21
    Andrew Unger
    I apologize I'm still a little new to this
    Apr 15, 2020 @ 13:29
    Alex Skrypnyk
    What is the type of Model?
    Apr 15, 2020 @ 13:34
    Andrew Unger
    I'm not sure and I'm not sure where to get that information
    Apr 16, 2020 @ 12:09
    Andrew Unger
    I ended up making it a macro and modifying the code a little but this is the macro I made if anyone has the same problem.
        var currentPage = Umbraco.TypedContent(UmbracoContext.Current.PageId);
        var typedMultiMediaPicker = currentPage.GetPropertyValue("largeCarousel");
        if (typedMultiMediaPicker != null)
            foreach (var item in typedMultiMediaPicker.ToString().Split(','))
                var img = Umbraco.TypedMedia(item);
                <div class="carousel-item active"><img src="@img.Url" alt="image3" class="image imageLarger" align="bottom"></div>
    I use this line of code to call the macro in my template
       <umbraco:Macro Alias="LargeCarousel" runat="server" />
