We are using Umbraco forms with a wizard, when you click next, it looks like a post method is invoked and this is being blocked by our firewall when hardening is enabled, the form works just fine when you set the security to basic on the firewall. It looks like this behavior occurs whenever you invoke a post request.
I have the same problem here.
Our Fortinet firewall sometimes blocks the post request from Umbraco Forms. In most cases with a larger form and when using () in answers.
It's giving me a "As-Is Based SQL Injection".
Did you already find any solution yet or has anyone else a suggestion or the same problems?
Firewall Blocking Post Requests
I have the same problem here. Our Fortinet firewall sometimes blocks the post request from Umbraco Forms. In most cases with a larger form and when using () in answers.
