Is there a reason why you give a Empty string as the culture? If not, try doing the search without the string.Empty. var v = Umbraco.ContentQuery.Search("my content name");
var easySearch = Umbraco.ContentQuery.Search("Products", "ExternalIndex");
Which means you are passing in the string "ExternalIndex" to the culture parameter.
Your options are to change your method call to one of these:
var easySearch = Umbraco.ContentQuery.Search("Products"); - which by default will query the ExternalIndex
var easySearch = Umbraco.ContentQuery.Search("Products", indexName: "ExternalIndex"); - to explicitly pass the string "Externalndex" to the right parameter
var easySearch = Umbraco.ContentQuery.Search("Products", null, "ExternalIndex"); - to pass all parameter values in the correct order
Using Content Query
Im trying to use Umbraco.ContentQuery in a controller to search for content by name but nothing is returned, is what I have below still valid?
var v = Umbraco.ContentQuery.Search("my content name", string.Empty); thanks
var v = Umbraco.ContentQuery.Search("my content name");-Joep
Hello Damio,
I umbraco v8, you should try this.
The syntax you are using is
var easySearch = Umbraco.ContentQuery.Search("Products");- which by default will query the ExternalIndexvar easySearch = Umbraco.ContentQuery.Search("Products", indexName: "ExternalIndex");- to explicitly pass the string "Externalndex" to the right parametervar easySearch = Umbraco.ContentQuery.Search("Products", null, "ExternalIndex");- to pass all parameter values in the correct orderhttps://github.com/umbraco/Umbraco-CMS/issues/5789
