  • nickornotto 403 posts 907 karma points
    Apr 28, 2020 @ 20:18
    nickornotto
    umbracoCssPath setting not working
    I added to my web.config:
    <add key="umbracoCssPath" value="~/content/dist/css" />
    It's supposed to change the default css path for Umbraco CMS to the one given in the value, according to the documentation: https://our.umbraco.com/documentation/reference/config/webconfig/
    But in backoffice Settings I can still see files that are within default /css folder.
    I have cleaned cookies, rebuilt, re-logged to no effect.
    I have version 7.15.3
    Apr 28, 2020 @ 20:51
    Alex Skrypnyk
    From docs - By adding this to appSettings you can specify a new/different folder for storing your CSS-files and still be able to edit them within Umbraco.
    It means that CSS files created in the Umbraco back-office will be created in that folder in the file system.enter image description here
    Alex
    Apr 28, 2020 @ 20:54
    Alex Skrypnyk
    when you change the folder, Umbraco doesn't remove files from the old folder
    Apr 29, 2020 @ 11:28
    nickornotto
    Ok, got it.
    However I don't need Umbraco to remove files from the old folder, but I don't want them to show up for editing within the CMS.
    Shall I remove them then in the CMS? But this will remove them in the file system I guess?
    Apr 29, 2020 @ 12:39
    Alex Skrypnyk
    Hi Nick,
    Just use any other folder to real CSS files and remove them from Umbraco Backend, also do backup before you do it.
    Alex
    Apr 29, 2020 @ 19:48
    Alex Skrypnyk
    Why do you want to prevent the CMS from editing CSS files? You can hide the settings section from some users to prevent security issues.
    Apr 30, 2020 @ 04:13
    nickornotto
    Because the css is bundled and built of sass, not really for editing outside of IDE.
    Apr 30, 2020 @ 14:59
    Alex Skrypnyk
    Ah, it makes total sense to move to another folder. then just move it to another folder and that's it.
