  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Apr 29, 2020 @ 09:54
    Dan Diplo
    How Examine Indexes HTML (Spacing issue)
    I've noticed when conducting an Examine search that words that appear in the main rich-text content weren't being matched in some instances. When I looked at the raw index I could see that Examine has stripped out HTML tags (which makes sense) but where this has happened it hasn't left any whitespace in their place. This causes adjacent words to run into each other in the index.
    To illustrate, take this original HTML content in the RTE:
    <p><b>Knowledge, Skills &amp; Abilities</b></p><ul><li><p>Excellent attention to detail, and ability to create wire-frames, user flows, mock-ups, interactive design and prototypes.</p></li><li><p>Excellent understanding of information architecture.</p></li><li></ul>
    When Examine indexes it, it is converted to plain-text like this:
    Knowledge, Skills &amp; AbilitiesExcellent attention to detail, and ability to create wire-frames, user flows, mock-ups, interactive design and prototypes.Excellent understanding of information architecture.
    You can see in the Examine index that where tags were removed that words run together, such as "AbilitiesExcellent" or "prototypes.Excellent" and this then messes up matching if you search for, say, "prototypes".
    So is there a way of getting it to replace tags with whitespace when indexing, to preserve words?
  • Lars-Erik Aabech 350 posts 1102 karma points MVP 8x c-trib
    Apr 29, 2020 @ 18:38
    Lars-Erik Aabech
    You could choose another analyzer/tokenizer for the fields in question.
    See example number two under Overriding index creation here:
    https://our.umbraco.com/documentation/Reference/Searching/Examine/indexing/
    I had the docs open and have just written a thing to index paths in parts, so it's was a bit lucky I can just gingerly paste this example. 😆
    public class IndexComposer : ComponentComposer<IndexComponent>
    public class IndexComponent : IComponent
        private readonly IExamineManager examineManager;
        public IndexComponent(IExamineManager examineManager)
            this.examineManager = examineManager;
        public void Initialize()
            if (!examineManager.TryGetIndex(Constants.UmbracoIndexes.ExternalIndexName, out var index))
                return;
            var coll = ((Examine.LuceneEngine.Providers.LuceneIndex) index).FieldValueTypeCollection;
            index.FieldDefinitionCollection.AddOrUpdate(new FieldDefinition("path", "csv"));
            coll.ValueTypeFactories.AddOrUpdate("csv", new DelegateFieldValueTypeFactory(s => new FullTextType(s, new WhitespaceAndCommaAnalyzer())));
            //index.FieldDefinitionCollection.
        public void Terminate()
    public class WhitespaceAndCommaAnalyzer : Analyzer
        public override TokenStream TokenStream(string fieldName, TextReader reader)
            return (TokenStream)new WhitespaceAndCommaTokenizer(reader);
        public override TokenStream ReusableTokenStream(string fieldName, TextReader reader)
            Tokenizer tokenizer = (Tokenizer)this.PreviousTokenStream;
            if (tokenizer == null)
                tokenizer = (Tokenizer)new WhitespaceAndCommaTokenizer(reader);
                this.PreviousTokenStream = (object)tokenizer;
            else
                tokenizer.Reset(reader);
            return (TokenStream)tokenizer;
    public class WhitespaceAndCommaTokenizer : WhitespaceTokenizer
        public WhitespaceAndCommaTokenizer(TextReader @in) : base(@in)
        public WhitespaceAndCommaTokenizer(AttributeSource source, TextReader @in) : base(source, @in)
        public WhitespaceAndCommaTokenizer(AttributeFactory factory, TextReader @in) : base(factory, @in)
        protected override bool IsTokenChar(char c)
            return base.IsTokenChar(c) && !','.Equals(c);
    Apr 29, 2020 @ 18:41
    Lars-Erik Aabech
                return;
            else
