  • Brian Bozarth 10 posts 59 karma points
    Apr 29, 2020 @ 13:23
    Brian Bozarth
    Stackable blocks in Umbraco
    What's the best way to do stackable content blocks in Umbraco 8? I want to have landing pages, where I can configure blocks in any order.
    In Episerver, I can create block types then attach them to the ContentArea in the Page Type.
    I was looking in Umbraco, and it seems like it should be Macros with Grid Layout. But when I set up the parameters for the Macro, the list is very limited. There's no Rich Text, List...
    Apr 29, 2020 @ 13:58
    Alex Skrypnyk
    Hi Brian
    Have a look at Nested Content, it should be exactly what you need.
    Docs here - https://our.umbraco.com/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Nested-Content/
    Alex
    May 05, 2020 @ 14:56
    Brian Bozarth
    What's the best way to do a shared block that be used across many pages? Would I do Nested Content with a link to the shared block? Where would that shared block live in the Content tree?
    May 05, 2020 @ 15:01
    Nik
    If you need them shareable/reusable, you'd want to create your own component store in a folder and then use a content picker to pick the blocks to include.
    If you go down the nested content route they are "create per page" type blocks. You might find you want a mix of both, so you could have a nested content block that contains a picker so you can combine both approaches.
    Nik
    May 05, 2020 @ 15:18
    Alex Skrypnyk
    I would create a separate folder with separate nodes and user Umbraco Node Picker to select the needed shared node where it's required
    Alex
  • Marc Love (uSkinned.net) 447 posts 1790 karma points
    2
    Hi Brian,
    Marc from uSkinned here. Our themes use the component approach that Nic mentioned. If you contact us via our contact form we can set you up with a demo to try it out.
    Marc
