I would like to create a list between a range of numbers with Razor, like the minimum number is 100,000 and the maximum is 1,200,000, so the list would be 100,000; 200,000; 300,000; ...1,200,000
100,000 would be the steps.
Unfortunately I have to put everything into a data attribute as a pricesList, so, so far I have this:
var developments = Model.Root().Children.Where(x => x.IsDocumentType("developments")).FirstOrDefault();
var prices = new List<int>();
var pricesList = "";
var priceValue = "";
var storedFloor = 0;
var storedCeiling = 0;
foreach (var development in developments.Children.Where(x => x.IsVisible())) {
var plots = development.Children.Where(x => x.IsVisible());
prices.AddRange(plots.Select(x => x.Value<int>("price")));
foreach (var price in prices.Distinct().OrderBy(x => x))
var floor = 0;
var ceiling = 0;
var storedPrice = price;
if(floor == ceiling){
storedPrice = price + 1;
floor = (int)(Math.Floor((int)price / 100000.0) * 100000);
ceiling = (int)(Math.Ceiling((int)storedPrice / 100000.0d) * 100000);
if(storedFloor != floor && storedCeiling != ceiling){
storedFloor = floor;
storedCeiling = ceiling;
priceValue = "£" + floor.ToString("#,##0") + " - " + "£" + ceiling.ToString("#,##0");
pricesList += "<option value='" + floor + "-" + ceiling + "'>" + @priceValue + "</option>";
This only gives me the min and max value by children, not together.
and i am not sure you wanted that (for example do you want the middle on to be £300,000 - £400,000) ?
So
Once you have all the prices grouped. If we assume that you just want the 100,000 ranges.
<select>
@for(int p = 0; p < prices.Count; p++)
var priceValue = string.Format("{0}-{1}", prices[p] - 1000000, prices[p]);
var priceString = string.Format("£{0:#,##0} - £{1:#,##0}", prices[p] - 100000, prices[p]);
<option value="@priceValue">@priceString</option>
</select>
this would return
£100,000 - £200,000
£300,000 - £400,000
£400,000 - £500,000
(if for example there are no 200,000 plot values)
So for compleatness (and with a step variable so you can change it).
@inherits UmbracoViewPage<IPublishedContent>
var priceStep = 100000;
// get all the prices from all the developments
// round them up, and then pick only distinct the rounded up values.
prices = prices.Select(x => (int)(Math.Ceiling(x / (decimal)priceStep) * priceStep))
.Distinct().OrderBy(x => x).ToList();
// loop through the rounded values and produce the list
<select>
@for (int p = 0; p < prices.Count; p++)
var priceValue = string.Format("{0}-{1}", prices[p] - priceStep, prices[p]);
var priceString = string.Format("£{0:#,##0} - £{1:#,##0}", prices[p] - priceStep, prices[p]);
</select>
Yeah, my bad. Now for loop is outside of the foreach. Much-much better, however, some values are missing 400,000-500,000 ; 500,000-600,000 ; 600,000-700,000 etc
foreach (var development in developments.Children.Where(x => x.IsVisible()) {
prices = prices.Select(x => (int)(Math.Ceiling(x / (decimal)priceStep) * priceStep)).Distinct().OrderBy(x => x).ToList();
for (int p = 0; p < prices.Count; p++) {
pricesList += "<option value='" + priceValue + "'>" + @priceString + "</option>";
They will be missing because there are no prices in those ranges ?
So there are two options,
you can either have all ranges, irrespective of them actually having values in ? e.g
100,000 - 200,000
200,000 - 300,000
300,000 - 400,000, etc
if so - you could probibly bypass the whole collection thing and put a for loop in to build them.
for(int p = priceStep; p < 1200000; p += priceStep)
// forloop will increment in 100,000's
// this doesn't need the prices array
var priceString = string.Format("£{0:#,##0} - £{1:#,##0}", p, p + priceStep);
or
If you still want to use the data but want the ranges to meet each other ,
e.g
£100,000 - £200,000
£200,000 - £300,000
£300,000 - £1,100,000
£1,100,000 - £1,200,000
then the first example did that, by doing the for loop from the second value (1 in the index) and then putting the p-1 value in the loop:
@for (int p = 1; p < prices.Count; p++)
var priceString = string.Format("£{0:#,##0} - £{1:#,##0}", prices[p - 1], prices[p]);
var priceValue = string.Format("{0}-{1}", prices[p - 1], prices[p]);
List of numbers between a range
I would like to create a list between a range of numbers with Razor, like the minimum number is 100,000 and the maximum is 1,200,000, so the list would be 100,000; 200,000; 300,000; ...1,200,000 100,000 would be the steps. Unfortunately I have to put everything into a data attribute as a pricesList, so, so far I have this:
Oh I like a little coding challenge 😊
I would swap the foreach out with a old school for loop, just because you can then go back in the loop to get the previous price.
So I assuming you are getting the prices from content nodes - into a list of ints called prices. if that list is ordered and a list.
UPDATE: OK so i missed that the prices where not the rounded numbers. the following will round those values into the nearest 100,000.
then i would use a for loop to start from the second item (1 in the index),
that gives you the list with ranges, .
OK,
I wasn't happy with that version :(
It returns whole lists e.g.
So
this would return
HI Kevin,
Thank you for your help. I tried the code, now I have this version. Only difference that everything goes into a data attribute, like this:
Unfortunately, don't know how, but the result is the same:
Maybe just need to order by value and exclude the duplicates. Is that possible?
yeah i would split the loops out.
so do this to get all the prices across all the plots.
then distinct and round etc. after the loop
then the
forloop - that way you get the distinct list across all developments,at the moment it looks like you are doing the for loop inside the other loop, not sure why is there a reason ?
or
e.g
Thank you Kevin for you help, you really nailed it. Cheers!!
