  • Andrew Unger 45 posts 148 karma points
    Apr 30, 2020 @ 18:25
    Andrew Unger
    "System.NullReferenceException: Object reference not set to an instance of an object." error when trying to render tags
    Hello I am trying to render tags I have set up for a blog page but I am having trouble. I am using version 7.13. I have the tags set up in the doctype with a few test tags already filled out in the content manager. I am using a Partial View Macro File to render the tags in my navigation. I have tried using different syntax than this as well as different methods with no luck. I would appreciate any help with this. I will post my code with a screen shot of the error I am getting.
            @{var items = blogNode.GetPropertyValue<IEnumerable<IPublishedContent>>("tags");}
             <ul>
                 @foreach(var item in items){
                    <li><a href="@item.Url">@item.Name</a></li>
             </ul>
    Apr 30, 2020 @ 18:28
    Alex Skrypnyk
    Hi Andrew,
    Use this code:
    @{var items = blogNode.GetPropertyValue<IEnumerable<string>>("tags");}
    @if (items != null)
    <ul>
        @foreach (var item in items)
    </ul>
    Alex
    Apr 30, 2020 @ 18:31
    Andrew Unger
    I tried that code and I am getting this error now
    Apr 30, 2020 @ 18:35
    Alex Skrypnyk
    Sorry, I did a mistake, each item in tags property is a string value
    Apr 30, 2020 @ 18:34
    Alex Skrypnyk
    What about this code:
    @if (items != null)
    <ul>
            <li>@item</li>
    </ul>
    Apr 30, 2020 @ 18:44
    Andrew Unger
    The error went away but its not displaying the tags. I have multiple content nodes with the same doctype that has the tags property. Could having multiple nodes with that doctype and property be a reason why its not working?
    Apr 30, 2020 @ 18:46
    Alex Skrypnyk
    no, you should see a list of tags with this code
    but you should change the logic that renders links, where the link should point?
    Apr 30, 2020 @ 18:54
    Andrew Unger
    Yea I was going to do that. I am planning on using a query string and having the tag that is clicked be the value in the query string and using that to filter out results. I am still not sure why the tags aren't displaying though.
    Apr 30, 2020 @ 19:37
    Alex Skrypnyk
    @if (items != null)
        <ul>
                <li><a href="@Umbraco.AssignedContentItem.Url?tag=@item">@item</a></li>
        </ul>
    What about this code? it should create a list of links of the same page and "tag" query string param with actual tag value
    Apr 30, 2020 @ 19:44
    Andrew Unger
    That didn't work either. Some of the content nodes don't have any tags filled out in the content manager. Most of them do have tags in there but could that cause issues? I know the alias is correct too so I'm not sure why its not working.
    Apr 30, 2020 @ 20:02
    Alex Skrypnyk
    we added this line to miss nodes that don't have tags property filled - @if (items != null)
    nodes that have this property should be rendered
    Alex Skrypnyk
    Can you share all view code?
    Apr 30, 2020 @ 20:03
    Andrew Unger
                var node = Model.Content;
                var blogNode = node.AncestorOrSelf("blog");
                var home = node.Site();
        <div id="blog-navigation" class="column small-12 medium-3">
            <div class="row">
                <div class="column small-12 line2">
                    <h2>@blogNode.GetPropertyValue("productsText", "Products")</h2>
                    <label>
                        <select class="select-search" placeholder="Select Product">
                            <option value="">Search...</option>
                            <option value="4">Thomas Edison</option>
                            <option value="1">Nikola</option>
                            <option value="3">Nikola Tesla</option>
                            <option value="5">Arnold Schwarzenegger</option>
                        </select>
                    </label>
                <div id="blog-projects" class="column small-12 line2">
                    <h2>@blogNode.GetPropertyValue("projectsText", "Projects")</h2>
            @* @if(blogNode.HasValue("tags")){
        @*@{var items = blogNode.GetPropertyValue<IEnumerable<IPublishedContent>>("tags");}
        @if (items != null)
        <ul>
        </ul>
        @if (items != null)
            <ul>
            </ul>
        @*@if (@blogNode.HasProperty("tags")) { string[] tagsList = blogNode.tags;
        if (tagsList.Count() > 0)
            <ul>
            @foreach (var tag in tagsList)
                 <li>@tag</li>
            </ul>
                    @*<ul>
                        <li><a href="#">Bath</a></li>
                        <li><a href="#">Closet</a></li>
                        <li><a href="#">Crafts</a></li>
                        <li><a href="#">Doors</a></li>
                        <li><a href="#">Kitchen</a></li>
                        <li><a href="#">Painting</a></li>
                        <li><a href="#">Walls</a></li>
                        <li><a href="#">Window</a></li>
                        <li><a href="#">Wood</a></li>
                    </ul>*@
                @if (blogNode.HasValue("featured"))
                    <div id="blog-featured" class="column small-12 line2">
                        <h2>@blogNode.GetPropertyValue("featuredText", "Featured") </h2>
                        <ul>
                            @foreach (var post in blogNode.GetPropertyValue<List<IPublishedContent>>("featured"))
                                <li><a href="@post.Url">@post.Name</a></li>
                        </ul>
                    <h2>@blogNode.GetPropertyValue("socialText", "Connect With Us")</h2>
                    <ul class="social">
                        @if (home.HasValue("facebook"))
                        { <li><a href="@home.GetPropertyValue("facebook")"><img src="/images/orange_social_icon-facebook.svg" alt="facebook"></a></li> }
                        @if (home.HasValue("twitter"))
                        { <li><a href="@home.GetPropertyValue("twitter")"><img src="/images/orange_social_icon-twitter.svg" alt="twitter"></a></li> }
                        @if (home.HasValue("linkedin"))
                        { <li><a href="@home.GetPropertyValue("linkedin")"><img src="/images/orange_social_icon-linkedin.svg" alt="linkedin"></a></li> }
                        @if (home.HasValue("youtube"))
                        { <li><a href="@home.GetPropertyValue("youtube")"><img src="/images/orange_social_icon-youtube.svg" alt="youtube"></a></li> }
                        @if (home.HasValue("instagram"))
                        { <li><a href="@node.GetPropertyValue("instagram")"><img src="/images/orange_social_insta-logo.svg" alt="instagram"></a></li> }
                    </ul>
    Apr 30, 2020 @ 20:08
    Alex Skrypnyk
    and what do you see on the page? is it just an empty space? maybe in markup?
    Apr 30, 2020 @ 20:10
    Andrew Unger
    I didn't see anything when I inspected the webpage
    Apr 30, 2020 @ 20:09
    Andrew Unger
    yea its just empty space where its supposed to be.
    Apr 30, 2020 @ 20:47
    Alex Skrypnyk
    if empty space then - items == null
    Can you check in /app_data/umbraco.cofing exactly this field in exactly this node?
    May 01, 2020 @ 12:16
    Andrew Unger
    Yea I have it open now what should I check about it?
    May 01, 2020 @ 12:30
    Andrew Unger
    yea that was the path for that too
    May 01, 2020 @ 13:46
    Alex Skrypnyk
    try to find blogNode there and check "tags" property, is it list of strings?
    May 01, 2020 @ 14:06
    Andrew Unger
    yea there is a list of strings where tag is
    May 01, 2020 @ 14:10
    Andrew Unger
    Could I not be using the correct node when using GetPropertyValue? Currently I have var blogNode = node.AncestorOrSelf("blog"); and I'm using that blogNode, and I tried Model.Content too but the tags still aren't printing out
    May 01, 2020 @ 14:31
    Andrew Unger
    Okay they are showing up now I figured it out. They are only getting displayed on the blog post page thats actually a page for the blog articles themselves, and they are not displaying on the blog page that has the links to those blog articles. I need to figure out how to get it to display on that blog page that has all the blog article links on it as well. Basically the user will click the tag and I am going to use jquery to print out links to articles that have that tag.
    May 01, 2020 @ 14:37
    Alex Skrypnyk
    Ah, great, at least we know that the code provided works, now we need to adjust it
    Can you show the tree how it looks in umbraco backend?
    May 01, 2020 @ 14:48
    Andrew Unger
    There is the top node blog that has the articles listed and then blog post is the child of that. Then that "blog" node is a child of a node called "About Us"
    May 01, 2020 @ 15:03
    Andrew Unger
    Okay so
       Model.Content.GetPropertyValue<IEnumerable<string>>("tags");
    will display the tags on the "blog article" page. "blogNode" doesn't display on either page.
    May 01, 2020 @ 15:41
    Alex Skrypnyk
    It's because of Model.Content always is the current page, so on the blog page you don't have these properties but you have them in blog article.
    May 01, 2020 @ 16:06
    Andrew Unger
    So then I would need to use something like this then?
    var blogPostNode = node.AncestorOrSelf("blogPost");
    May 01, 2020 @ 16:11
    Andrew Unger
    Okay I was able to figure it out. I used this and it works for both the blog page and blog article page
    var blogPostNode = node.DescendantOrSelf("blogPost");
    May 01, 2020 @ 16:14
    Alex Skrypnyk
    oo nice solution, but just to let you know that DescendantOrSelf is a quite expensive method in terms of performance if there are too many nodes under the current node
    May 01, 2020 @ 16:22
    Andrew Unger
    Thank you for that tip and for all your help with this you're a life savor as usual
    May 01, 2020 @ 16:24
    Alex Skrypnyk
    You are always welcome, have a great weekend, keep safe and keep asking questions :)
    May 01, 2020 @ 17:02
    Andrew Unger
    So I did run into another issue. The only tags that show up are of the first child of the blog page. I need to get all the tags from all the child nodes of blog.
    May 01, 2020 @ 20:20
    Andrew Unger
    I ended up finding a solution to that last problem but its a little messy. Just in case anyone else has a similar issue this is how I solved only printing the tags once. I used a string to put all the tags into, and then I used .Distinct()); in that string to get rid of duplicates, and another for loop to print out all the tags that are distinct.
                        var children = blogNode.Children.Where("Visible");
                    @foreach (var child in children)
                        var currentChild = child.GetPropertyValue<IEnumerable<string>>("tags");
                        if (currentChild != null)
                                <ul>
                                    @foreach (var item in currentChild)
                                        childResults += @item + " ";
                                </ul>
                @{result = string.Join(" ", childResults.Split(' ').Distinct());
                string[] strSplit = result.Split();
                var last = strSplit.Last();
                <ul>
                    @foreach(var eachResult in strSplit){
                        if (eachResult.Equals(last))
                            @*do nothing for the last entry because it prints out nothing*@
                        else{
                            <li><a href="@blogNode.Url?tag=@eachResult">@eachResult</a></li>
                </ul>
