What I am trying to achieve is in grid layout allow editors to put in components and separate them with a divider. I am also using Umbraco graphql package.
So when i make graphql query the view label.cshtml is being called and I get back json that all works fine.
In the backoffice when I add the divider component I get the following error:
Authorization error: Unauthorized access to URL:
/App_Plugins/MyNavy/label.cshtml
Its trying to load the label.cshtml instead of the label.html which is the render one. If I swap render and view values then the backoffice error goes away but then I get error on graphiql
Grid component view and render templates
Using umbraco 7.15.3 I have grid set up and in my grid json I have the following:
} What I am trying to achieve is in grid layout allow editors to put in components and separate them with a divider. I am also using Umbraco graphql package.
Am I missing something?
Ok ignore, I just updated again but then did a build now it all works,
