  • Josip 195 posts 662 karma points c-trib
    May 06, 2020 @ 20:23
    Josip
    Content manipulation between applications
    Hi all,
    Is it possible to manipulate the content from www.example1.com on second application www.example2.com?
    This applications are completly separated.
    Help please :)
    May 06, 2020 @ 20:50
    Alex Skrypnyk
    Hi Josin
    No, you can't
    It would be huge security issue if possible :) You need some kind of connection between sites and some kind of actions to make changes.
    Alex
    May 07, 2020 @ 10:08
    Josip
    Hi Alex,
    What I wanted to do is when member creating account on website1 to check if account with that username exist on website2 if not than create it.
    Is there any way to achieve it?
    BR
    May 07, 2020 @ 10:30
    Alex Skrypnyk
    Hi Josip,
    You can create a combination of events and API. Just call website2 API methods in the member creation event of a website1.
    Alex
    May 07, 2020 @ 10:55
    Josip
    I was thinkig about it, do you know where I should look for some example? I tried to find something to start with but I am not sure what I am looking for.
    BR
    May 07, 2020 @ 11:07
    Alex Skrypnyk
    I can't find docs page for MEmber Events, but this is how to subscribe to the event - https://our.umbraco.com/documentation/getting-started/Code/Subscribing-To-Events/
    About events in general - https://our.umbraco.com/documentation/Reference/Events/
    How to create an API controller in Umbraco - https://our.umbraco.com/documentation/reference/routing/webapi/
    May 07, 2020 @ 11:57
    Josip
    Okay, thank you Alex, so API controller is way to go. With events I was working before so I am familiar with it, the only unkown area for mi is comunication between 2 separated applications
    BR
    Josip
