  • Meghana Lokrey 5 posts 95 karma points
    May 11, 2020 @ 17:43
    Meghana Lokrey
    Multi-Url Picker in V8.5
    Hi, I am in process of upgrading to version 8.
    I need the list of CalendarEvent (doctypealias: calendarEvent) under Calendar (doctypealias: calendar) node. On a page (doctyealias:CalendarListPage) has a multi-url picker Calendar (multi-urlproperty) and code grabs its Id. Based on the Id picks list of CalenderEvents
    This is what I have in 7.12.3. @inherits Umbraco.Web.Mvc.UmbracoTemplatePage
    @{ var calendarNode = Umbraco.Content(CurrentPage.calendar.Id);
    var calendarEvents = calendarNode.calendarEvents.Where("Visible").OrderBy("StartDateTime");
    @foreach (var calendarEvent in calendarEvents) { code here }
    In version 8 I have @inherits Umbraco.Web.Mvc.UmbracoViewPage @{ var calendarNode = Model.Calendar.Id; var calendarEvents = calendarNode.CalendarEvents; }
    I get an error at CalendarEvents 'int' does not contain a definition of CalendarEvents
    Any insight helpful. -Meg
  • Nik 1617 posts 7263 karma points MVP 7x c-trib
    May 11, 2020 @ 20:43
    Nik
    Hi Meg,
    I think you could try:
    @inherits UmbracoViewPage<CalendarListPage>
        var calendarNode = Model.Calendar;
    See if that clears up your error.
    Nik
    May 11, 2020 @ 21:11
    Meghana Lokrey
    Hi Nik,
    It gives an error "IPublishedContent" does not contain a definition for "CalendarEvents"
    May 12, 2020 @ 13:47
    Meghana Lokrey
    I solved it.
    @{ var calendarNode = Model.Calendar.Id; var calendarEvents = Umbraco.Content(calendarNode).ChildrenOfType("calendarEvent"); }
        <div class="row">
            <div class="medium-10 small-8 columns">
                <h5>@calendarEvent.Name</h5>
                @Html.Raw(calendarEvent.Value("eventDescription"));
                @if (calendarEvent.HasValue("eventLinks"))
                    <br />
                    var links = calendarEvent.Value<IEnumerable<Link>>("eventLinks");
                    foreach (var item in links)
                       // var linkUrl = (item.HasProperty("External")) ? item.Value("link") : item.Value("link");
                        <br /><a href="@item.Url" target="@item.Target">@item.Name</a>
                <br />
                <br />
