  • Hemika 4 posts 74 karma points
    May 13, 2020 @ 05:50
    Hemika
    Always getting ApplicationContext.Current = NULL in external library project
    I have created a new Library project which is outside of Umbraco itself.
    Now, In the Library Project, I always get "ApplicationContext.Current = NULL" So I have googled all the things but not getting works. So after getting disappointed from everywhere I have posted in Umbraco Forum.
    Kindly help me with "How to fill AppliactionContext.Current" in the external library project.
    My library project code as below : Umbraco version 7.3.0 assembly: 1.0.5750.18157
    public void ProcessRequest(int requeatId)
            #region Application Context
                   var applicationContext = ApplicationContext.Current;
            #endregion
    Kindly help me to resolve an issue as soon as possible.
    May 13, 2020 @ 08:16
    Ismail Mayat
    Take a look at https://github.com/sitereactor/umbraco-console-example this may give you some pointers, you need to wire everything up also you will need the web.config pointing to the umbraco database.
    May 13, 2020 @ 12:28
    Hemika
    I don't have to host this library project anywhere.
    Here the flow is like : When a user clicks on any submit button one API is called from that API need to call another library project which hosted on another server.
    Now On that project, I am not able to get ApplicationContext.Current.
    I have tried the same flow of UmbracoBootManager and all but it gives me the following error : "Current has already been initialized on Umbraco.Core.Logging.LoggerResolver. It is not possible to re-initialize Current once it has been initialized."
    Sometimes it can be a different error than this one.
    I am always getting error at below point : enter image description here
