  • Mikael Axel Kleinwort 154 posts 499 karma points c-trib
    May 15, 2020 @ 19:14
    Read svg from media library
    In Umbraco 8.5, I want to include the content of image media items of type SVG directly in html markup inside of a partial view with @Html.Raw(...)
    What is the best way to retrieve the content of the media items so the data is properly cached?
    This is what works for me right now:
        @Html.Raw(System.IO.File.ReadAllText(Server.MapPath(img.Url)));
    but this seems to be not cache-friendly.
  • Dmitriy 168 posts 588 karma points
    May 16, 2020 @ 18:04
    Dmitriy
    Do you want just render SVG to page's DOM?
    You can avoid manual file IO operation and render the only URL to DOM and then use a JavaScript library (like svg4everybody) that handles the URL and append file content into DOM.
    May 21, 2020 @ 15:18
    Dmitriy,
    thank you for taking the time to answer. I want to be able to modify part of the svg tags prior to rendering, this is why I am looking for a server-side, cache-friendly solution to this.
    May 21, 2020 @ 16:12
    Alex Skrypnyk
    Hi Mikael
    The problem with code you use is IO library, the slowest part is reading the file from the disk.
    I would recommend you just add caching to the Partial level for example, it's super easy to do with Umbraco helper Html.CachedPartial
    Alex
    May 21, 2020 @ 16:23
    Alex.
    great to hear from you. Thank you for pointing out the obvious to me! :-)
    I was suspecting that there might be a better "Umbraco" way to get to the svg content apart from using the IO library, but keeping this code and caching the partial is a great idea. Thanks again.
