Hi all, Every time I hit settings button in my Umbraco, I get this error (see image).
i tried url redirect, but either I didn't do it well, or it's not the correct solution. Can anybody help?
thanks, Rotem
Anyone?
As usual, I will answer myself.
It seems the issue was a URL rewrite rule that I had for adding trailing backslash.
I just added the following line to the rewrite rule:
<add input="{URL}" pattern="\.axd$" negate="true" />
so the full rule is:
<rule name="Add trailing slash" enabled="true" stopProcessing="true"> <match url="(.*[^/])$" /> <conditions> <add input="{HTTP_URL}" pattern="^.*/(ucommerce.*|payment-page.*|login-wizard|customer-success|umbraco|umbraco_client|client|install|api|App_Plugins)" negate="true" /> <add input="{URL}" pattern="\.axd$" negate="true" /> <add input="{HTTP_HOST}" pattern="localhost" negate="true" /> <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" /> <add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" /> <add input="{REQUEST_FILENAME}" pattern="(.*?)\.xml" negate="true" /> </conditions> <action type="Redirect" redirectType="Permanent" url="{R:1}/" /> </rule>
That stopped the redirect for the webResource.axd and scriptResource.axdm, and solved the issue, as the original problem was that both of this files return 404.
Cheers
Mixed content issue on settings
thanks, Rotem
Anyone?
Cheers
