    May 28, 2020 @ 08:42
    Ismail Mayat
    cut and paste many tags
    In v7 using the tags property editor you can type in more than one tag just have press return key. Is it possible to paste in multiple tags?
    So lets say you paste in item1 item2 item3 that will be created as 1 tag when you press enter, is there something else like putting in linefeed characters to get it to treat the pasted as string as multiple tags? I tried:
    1111\r\n2222\r\n3333\r\n4444\r\n5555
    but it tried it all as one.
  • Steve Morgan 1350 posts 4460 karma points c-trib
    May 28, 2020 @ 08:53
    Steve Morgan
    If you enter them as 1111,2222 then click off it will incorrectly display them as one tag.
    Then when you save and publish it will "fix" the json in the back... or so it seems.
    Probably best to test this behaviour!
    May 28, 2020 @ 08:55
    Steve Morgan
    Entered "demo,umbraco" enter image description here
    Then save and publish... enter image description here
    May 28, 2020 @ 08:57
    Ismail Mayat
    Steve,
    Woot, that works a treat. Working on something where we need to tag but client will be entering cut and paste of potentially big list and does not want to be typing each one then pressing tab.
    Many thanks for this, I thought i would have to create new tag editor to enable this.
    May 28, 2020 @ 09:40
    Ismail Mayat
    hmm may be spoke too soon, see
    in content view looks fine but in db it is stored as one big tag. So I am thinking maybe i need to tap into save / publish event and get the tag then check if its got , then split it out and re add as separate tags.
    May 29, 2020 @ 08:16
    Steve Morgan
    URGGH!!
    Yeah a publish intercept might be the way to go. Seems like a bug to me though... should be able to copy and paste csv in.
    Will find some time and test this in v8...
