  • nickornotto 403 posts 907 karma points
    May 31, 2020 @ 11:43
    nickornotto
    Problem serialising umbraco model because of loop referencing
    I am trying to return search results.
    The search return a list of product models which has prices with nested content property.
    I am getting a serialisation error:
    ExceptionMessage: "The 'ObjectContent`1' type failed to serialize the response body for content type 'application/json; charset=utf-8'."
    ExceptionType: "System.InvalidOperationException"
    InnerException: {Message: "An error has occurred.",…}
    ExceptionMessage: "Self referencing loop detected for property 'ContentType' with type 'Umbraco.Core.Models.PublishedContent.PublishedContentType'. Path 'Data.Result.Products[0].Price.PricesNc[0].ContentType.PropertyTypes[0]'."
    ExceptionType: "Newtonsoft.Json.JsonSerializationException"
    Not sure what to do with it as I need to return products with prices.
    I tried ignoring the referencing on serialisation as per Muhammad Omar advice here: https://stackoverflow.com/questions/7397207/json-net-error-self-referencing-loop-detected-for-type
    or in Global.asax.cs as per Bishoy Hanna's advice here: https://stackoverflow.com/questions/7397207/json-net-error-self-referencing-loop-detected-for-typehttps://stackoverflow.com/questions/13510204/json-net-self-referencing-loop-detected
    but it's just causing StackOverflowException - I guess the reference is still there and it's looking witout end.
    I am not sure what to do with it and how get around so I get the results serialised?
    Jun 01, 2020 @ 13:17
    Ismail Mayat
    Can you show your search source code? I suspect you are using typedsearch and that is sending back list of IPublishedContent? If so then you need to transform that list of ipublihsed content to your own list of model to fix this.
    You cannot send back IPublishedContent directly from webapi in Umbraco.
    Regards
    Ismail
    Jun 03, 2020 @ 05:23
    nickornotto
    I tried it already as you suggested but it still failed. (I always use models)
    So in the case you explain it won't work even if I cast it to builder's model because a model always carry a property Content which is of type IPublishedContent.
