  • bh 444 posts 1544 karma points
    Jun 02, 2020 @ 15:34
    bh
    First Time Using Grid Editor - Fail
    I've never used the grid editor before. But, I feel like I've got the perfect use case for one now, so I tried adding one, and failed.
    I get this error when I go to my page now that contains the grid editor.
    Cannot deserialize the current JSON array (e.g. [1,2,3]) into type 'Umbraco.Core.Models.GridValue' because the type requires a JSON object (e.g. {"name":"value"}) to deserialize correctly. To fix this error either change the JSON to a JSON object (e.g. {"name":"value"}) or change the deserialized type to an array or a type that implements a collection interface (e.g. ICollection, IList) like List
    What I'm trying to accomplish...
    I want the user to be able to add a row of either 2 or 3 columns (4x4x4 or 4x8 or 8x4). I would like the editor for those 3 columns to reuse an existing editor I've already configured that I call CopyBlock (this has two text boxes and an RTE). I see where I can select from RTE, Image, etc. Is it possible to choose an existing editor not in that list?
    Jun 02, 2020 @ 16:58
    bh
    Not a solution but more of a work around.
    I created an Element Type DocType called nceCol. nceCol has 3 properties, leftContent, centerContent, rightContent. The property editor for each is CopyBlock which is an implementation of the ncCopy Element Type that has 3 property Title (textbox), Subtitle (textbox), WYSIWYG (rte).
    It's not as robust/flexible as a custom grid editor. But, it'll get the job done.
