  • Dan Hammond 7 posts 28 karma points
    Jun 05, 2020 @ 07:44
    Dan Hammond
    How do you create a composite primary key with Umbraco's Migration system?
    I am trying to create a simple table using Umbraco's database migration system, and I can't figure out how to create a table with a composite primary key.
    Here's an example of the code I am trying to use:
    using Umbraco.Core.Migrations;
    using Umbraco.Core.Persistence.DatabaseModelDefinitions;
    using DbConstants = MyProjects.Data.Constants.Database;
    namespace MyProjects.Data.Migrations
      public class _00_Create : MigrationBase
        public _00_Create( IMigrationContext context ) : base( context ) { }
        public override void Migrate()
          if ( !TableExists( DbConstants.TBL_NAME ) ) {
            Create.Table( DbConstants.TBL_NAME )
              .WithColumn( "Composite1" )
                .AsString( 40 )
                .NotNullable()
                .PrimaryKey( "PK_Composite1" )
              .WithColumn( "Composite2" )
                .AsString( 40 )
                .NotNullable()
                .PrimaryKey("PK_Composite2")
              .WithColumn( "DateAdded" )
                .AsDateTime()
                .WithDefault( SystemMethods.CurrentDateTime )
              .WithColumn( "DateUpdated" )
                .AsDateTime()
              .Do();
    The above is only an example of what I'm trying to do, hence the rubbish column naming.
    I am aware that there's a way to pass a type into the Create.Table method instead, but I have read that it's inadvisable to use that method with migrations.
    Is someone able to explain how to create such a table using Umbraco Migrations?
    Jun 08, 2020 @ 07:26
    Dan Hammond
    Sorry to bump this, but I still haven't figured it out.
    Could anyone advise?
