  • Neil Hodges 338 posts 987 karma points
    Jun 09, 2020 @ 14:13
    Neil Hodges
    V7 - Examine Index Locking - Multi Domain
    I'm having a problem with Examine Index constantly locking. We are running 2 Domains from Umbraco.
    • Domain 1 - Home
    • Domain 2 - Home
    They are slightly different versions of the website, so independently they are specific, use specific and shared templates.
    Hosted on a dedicated server: Server: Windows 2012 R2 Umbraco: v 7.15.3 App Pool: Both Domains running under the same IIS App Pool.
    NO load balancing, NO Azure. NO CDN.
    When a Member signs up, my code executes and it does sign them Ok, but I'm getting the InternalMemberIndexer continually locking up. It's not just limited to this Indexer, sometimes the site crashed as the indexes are locked when just navigating around each one of the sites.
    The stack trace is:
         2020-06-09 14:29:46,773 [P4912/D3/T60] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:46,788 [P4912/D3/T60] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:46,898 [P4912/D3/T60] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:46,960 [P4912/D3/T14] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:47,070 [P4912/D3/T54] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:47,085 [P4912/D3/T54] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:47,179 [P4912/D3/T57] INFO  UmbracoExamine.DataServices.UmbracoLogService - Field "email" is listed multiple times in the index set "InternalMemberIndexSet". Please ensure all names are unique, Provider=InternalMemberIndexer, NodeId=24102
     2020-06-09 14:29:47,210 [P4912/D3/T75] INFO  Umbraco.Web.Mvc.UmbracoPageResult - Executing Umbraco RouteDefinition controller
     2020-06-09 14:29:47,288 [P4912/D3/T75] INFO  Umbraco.Web.Mvc.UmbracoPageResult - Finished (took 75ms)
     2020-06-09 14:29:48,492 [P4912/D2/T47] ERROR UmbracoExamine.DataServices.UmbracoLogService - Provider=InternalMemberIndexer, NodeId=-1
    But essentially this keeps cropping up, the Member emails don't get sent out for member verification as the error I'm seeing is that the Index is locked.
    System.Exception: Cannot index queue items, the index is currently locked,, IndexSet: InternalMemberIndexSet
    Any idea how I can get this to stop locking the index? Setting up a multi-domain Umbraco instance do I need some special config settings?
  • Paul Wright (suedeapple) 277 posts 704 karma points
    Jun 09, 2020 @ 16:15
    Hmmmm i can see why and how this would crop up.
    As the "member" would think the sites are separate, but they actually share the same "member base".
    Have you tried switching on "Use Unique Username", but switch off "Use Email As Username".
    Jun 09, 2020 @ 16:30
    Neil Hodges
    Each Member is being created with a separate Member Type though.
    Each with their own set of properties.
    There was a separate Email field I did have in the Member Types as it was needed for Dialogue to work. I've removed it and tried to sign up as a member but still get the locking error.
    There is another locking error if I restart the site in IIS
    ---> (Inner Exception #0) Lucene.Net.Store.LockObtainFailedException: Lock obtain timed out: SimpleFSLock@D:\inetpub\website\App_Data\TEMP\ExamineIndexes\InternalMember\Index\write.lock
    So there is defo something wrong with 2 sites reading and writing to the same Examine Index.
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Jun 09, 2020 @ 16:31
    Dave Woestenborghs
    Hi Neil,
    Do you have 2 IIS sites point to the same website folder ? That is not supported.
    dave
    Jun 09, 2020 @ 16:33
    Neil Hodges
    Yep
    • DomainName 1
    • DomainName 2
    Both point to the same Website in IIS, Then within Umbraco,
    I have Hostnames as :
    Home - DomainName1 (Node)
    Home - DomainName2 (Node)
    Jun 10, 2020 @ 09:39
    Dave Woestenborghs
    Multiple IIS websites pointing to the same umbraco folder is not supported. This will lead to the locking issue you are describing.
    It's better to have one IIS website and have multiple domain bindings on that one.
    Dave
    Jun 10, 2020 @ 10:19
    Neil Hodges
    Ah-ha, I see.
    So my setup of having 2 IIS websites is the problem.
    Just setting up the bindings on the singular website to have
    Then let Umbraco route to the correct (Home) node using 'Culture & Hostnames' should do the trick?
    Jun 10, 2020 @ 10:56
    Dave Woestenborghs
    Yep
    that should do the trick.
    Dave
    Jun 09, 2020 @ 16:50
    Have you had a look at the Member with ID of 24102?
    Anything untoward? or Strange? - Might be worthwhile, taking a backup of the entire site. Removing all the Members, and seeing if/when the errors kick in.
    Jun 09, 2020 @ 18:04
    Neil Hodges
    Yeh, the ID pertains to the new Member created.
    I think it's more to do with 2 domains accessing the same Website in IIS. All be it they are the same site structure-wise, just different templates here and there and completely different CSS and imagery.
    Even though they are on separate Domains and Nodes in Umbraco it seems setting 2 sites to point at the same folder/Umbraco install in IIS can't be done?
    Jun 09, 2020 @ 18:53
    Sounds peculiar - as this is typically how multilingual site are set up in Umbraco. (different domains pointing to the same umbraco solution)
    Has the site been upgraded from a previous version? - and do you have any extra profile data you store against the member?
    Jun 09, 2020 @ 19:03
    Neil Hodges
    Yeh, I thought that as well, multilingual sites are done in a similar way, however, in my instance, they are two completely different domain names. Wonder if that makes a difference?
    So the structure:
    • domain.com
    • domain.com/en/
    • domain.com/fr/
    Should be Ok as they are the same domain?
    would:
    • en.domain.com
    • fr.domain.com
    be Ok as well?
    In my instance I have:
    • domain1.com
    • domain2.com
    I've upgraded from a lower version of Umb V7, think it was around 7.10, so not a major jump, to now upgraded 7.15.5. Maybe something amiss if it was upgraded from Umb 6 or 4, but we built it in the high 7s, so I can't think it would be that.
    Profile data/properties differ slightly between Member Types. But that's just text strings and a few multinode tree pickers. Nothing out the ordinary.
    Jun 09, 2020 @ 21:32
    I've used both scenarios for numerous multilingual sites, using completely different hostnames, or subfolders. And not hit this member indexing issue.
    What I have seen happen is when a site gets upgraded from earlier versions the XML generation fails if a string contains a special (or hidden character). Typically when the text has been copied from a MAC device, or Word Document. (I could be barking up the wrong tree).
    My first port of call would be to copy the site, remove all the member data, and see if you get the same errors. Then you'll know for sure, if its something to do with the profile data, against a particular member.
    Deffo : NeedleAndHaySack
    Good luck!
    Jun 09, 2020 @ 21:40
    ....There was a separate Email field I did have in the Member Types as it was needed for Dialogue to work.....
    Are you sure you didn't name this custom property "email" ?? - Just checking :)
