So when I add any new page from admin website umbraco generates the URL like http://www.admin.mywebsite.com/test but ideally it should be like – “http:// www.mywebsite.com/test”.
I am confused it should work with both urls. If you look at info tab of a page in backoffice you will see urls for admin and website and both should work
Umbraco load balancing - Url Generation
I am new to umbraco.
I have setup the Load balancer for our umbraco website in which our admin and front websites are on different server.
Please see the URLs below,
Admin –http://www.admin.mywebsite.com/umbraco
Front – http://www.mywebsite.com
Can someone help me to resolved this?
Thanks, in advanced…
In umbraco on the root node has the domain www.mywebsite.com been added?
Yes, I have added domain,
when generating custom url need to set like http://www.mywebsite.com/test.
Can you please suggest any solution
In umbraco back office set domain for http://www.mywebsite.com.
Using content finder we implement custom generate url.
So,if generate custom seo then url not generated based on domain setup.
