  • David Nevin 9 posts 100 karma points
    Jun 15, 2020 @ 20:31
    David Nevin
    SMTP on asphostportal using SmarterMail Web
    Hello, has anyone setup SMTP on asphostportal using SmarterMail Web Client 10.7.4842? Please can you advise what are the correct details for the Umbraco config file?
    <smtp from="noreply@example.com">
                    <network host=“127.0.0.1" userName=“username” password=“password” />
                </smtp>
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Jun 16, 2020 @ 15:03
    Steve Morgan
    According to this: http://faq.asphosthelpdesk.com/article.php?id=82
    You just need:
                    <network host="localhost" userName="emailaccount"password=“emailaccountpassword” />
                </smtp>
    It suggests you need to create an email account and use those details rather than your primary host login.
    Be very careful with speech marks “ is not the same as " in the webconfig (they are angled if you look carefully)
    Jun 17, 2020 @ 12:47
    David Nevin
    Hi Steve,
    thanks so much for the replies. What you suggested didn't work exactly, but when I created an additional account, as you suggested, as opposed to the primary, and used mail.mydomain.com as the server it worked.
    Using Localhost gave me an error in the Umbraco health check under services.
    Thanks a million.
  • John Palmer 77 posts 202 karma points
    Jun 17, 2020 @ 05:25
    John Palmer
    Hi David,
    You can contact their support team directly.
