  • Martin Rud 261 posts 1022 karma points c-trib
    Jun 16, 2020 @ 06:47
    Martin Rud
    Previous and next links for nodes in a category structure
    I have a FAQ section with this structure:
    • FAQ overview
      • FAQ item 1
      • FAQ item 2
      • FAQ item x
    For this I have this working code on the FAQ item template that creates next and prev links:
    IPublishedContent parent = Umbraco.AssignedContentItem.Parent;
    IEnumerable<IPublishedContent> children = parent.Children;
    List<int> childrenIds = children.Select(x => x.Id).ToList();
    int currentIndex = childrenIds.IndexOf(Umbraco.AssignedContentItem.Id);
    IPublishedContent prev = null;
    IPublishedContent next = null;
    if (currentIndex > 0)
        prev = children.ElementAt(currentIndex - 1);
    if (currentIndex < (children.Count() - 1))
        next = children.ElementAt(currentIndex + 1);
    @if (prev != null)
        <a class="prevnext prev" title="@prev.Name" href="@prev.Url">Prev</a>
    @if (next != null)
        <a class="prevnext next" title="@next.Name" href="@next.Url">Next</a>
    But for this strucure I need to tweak the code. Any hints?
    • Event overview
      • Event category 1
        • Event item 1
        • Event item 2
        • Event item x
      • Event category 2
        • Event item 1
        • Event item 2
        • Event item x
      • Event category x
        • Event item 1
        • Event item 2
        • Event item x
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Jun 16, 2020 @ 14:54
    Steve Morgan
    You should be able to use similar logic.
    I'm assuming this is in a partial which is why you're using AssignedContentItem..
    Change
    To: (updating the doc type alias to match yours)
    var eventOverview = Umbraco.AssignedContentItem.AncestorOrSelf("eventOverviewDocTypeAlias");
    And then
    To (updating the doc type alias to match yours)
    var children = eventOverview.DescendantsOfType("eventItemDocTypeAlias");
    NOTE: you will have to change "eventOverviewDocTypeAlias" and "eventItemDocTypeAlias" to be the doc type aliases that match yours - this is the event landing page and the one for the individual the event items. You can get this from the Info tab, over over the text under "Document Type". It will usually be in camelCase, this is important.
    I hope this helps.
    Steve
    Jun 16, 2020 @ 17:47
    Martin Rud
    Great! Thank you. That did the trick.
    Since I have only one document type of items to user it for that is structured in categories (the others are child nodes of the index page) I have changed the code to be generic for my setup:
    IPublishedContent root = null;
    if(Model.ContentType.Alias == "uge30_activity")
        root = Umbraco.AssignedContentItem.AncestorOrSelf("uge30_activities_index");
    } else {
        root = Umbraco.AssignedContentItem.Parent;
    var children = root.DescendantsOfType(Model.ContentType.Alias);
    The "uge30_activity" is the only one not directly put under the overview pages.
