  • Henrik Sunesen 85 posts 282 karma points
    Jun 21, 2020 @ 14:36
    Henrik Sunesen
    Call method in Surface controller from hangfire
    Hello all,
    I'm trying to call a method in one of my surface controllers from hangfire. But i'm getting a "Object reference not set to an instance of an object." exception.
    As far as I can read the problem is, that controllers is not made for this.
    But what is the right way, if I need to have access to Contentservice in a method, that needs to work as a hangfire cronjob?
    An example:
     public void DoSomething()
            //Creating instance of the surface controller
            MailController mail = new MailController();
            RecurringJob.AddOrUpdate(() => mail.SendCSV("test"), Cron.Minutely);
    OwinStartup Class:
      public class UmbracoStandardOwinStartup : UmbracoDefaultOwinStartup
        public override void Configuration(IAppBuilder app)
            //ensure the default options are configured
            base.Configuration(app);
            // Configure hangfire
            var options = new SqlServerStorageOptions { PrepareSchemaIfNecessary = true };
            const string umbracoConnectionName = Umbraco.Core.Constants.System.UmbracoConnectionName;
            var connectionString = System.Configuration
                .ConfigurationManager
                .ConnectionStrings[umbracoConnectionName]
                .ConnectionString;
            GlobalConfiguration.Configuration
                .UseSqlServerStorage(connectionString, options);
            // Give hangfire a URL and start the server
            app.UseHangfireDashboard("/hangfire");
            app.UseHangfireServer();
            var scheduler = new ScheduleHangfireJobs();
            scheduler.DoSomething();
  • Walter 4 posts 94 karma points
    Jun 21, 2020 @ 20:09
    Walter
    Hi, to consume an umbraco content from third party applications, you need to build a UmbracoApiController (API) which is similar to surface controller (MVC).
    https://our.umbraco.com/Documentation/Reference/Routing/WebApi
    Jun 25, 2020 @ 20:05
    Henrik Sunesen
    Hi Walter,
    Thank you, that helped me so much!
