Hi!
I have a multisite v8 setup with one hostname per node, e.g.:
Root + doc1 (has hostname domain1.com) + doc2 (has hostname domain2.com)
When I browse to http://domain2.com/doc1 it serves up doc1 (still under the url http://domain2.com/doc1).
Is this by design?
Is there any way to prevent this?
I have tried adding useDomainPrefixes=true to umbracoSettings.config but this doesn't work in v8 (it returns a YSOD).
I was wondering if this is solved through a ContentFinder (or if I have to remove a ContentFinder from the pipeline).
Any suggestions are greatly appreciated :-)
Thanks in advance.
Regards, Jan
P.S. I am on Umbraco v8.1.5
Problem with crossdomain document references on v8 multisite solution
Hi!
Is this by design?
Thanks in advance.
Regards, Jan
