I'm having an issue with media and RTE and its really strange!
So I have a website which is running usync, I wanted to create a copy of this and tweak it for another project. So what I did was installed latest version of Umbraco and did a usync export of the website I want and imported it onto the new project.
Great, everything worked, all the images content showed how I want. my issue now is if I make any changes to my RTE this then causes the images not to show once published... even tho they appear in the editor windows....
Also if I then go to add any images via RTE they will upload, show on the editor window but if I publish again they wont appear.
If I remove the data udi="umb://media/e08b6a6425ac404fa43c075af7f97e05" from the source then the images appear.... Although I cant expect an editor to remove this every time they add an image.
Issue with Media and RTE
Hi all,
Any pointers?
Just to update this should anyone come across it.
after looking into it, it looks like the partial file for rendering RTE Elements in the grid (
/views/partials/grid/editors/rte.cshtml) was from a site pre Umbraco v8.2.1 - ( https://github.com/umbraco/Umbraco-CMS/commit/5e684487c07994ceb6ad553b42b82279bd1cb59b#diff-9c6801ce6015cf82d1ce2a5c583d9874 )there is a fix in umbraco v8.2.1 that adds a additional lines to this file to fix images not showing up in the grid.
Copying over the views from the old site appears to have done this (its what i would have done!).
advice might be don't overwrite the the
views/partials/gridfolder when bringing in files from an old install.is working on a reply...
