I have recently upgrade my umbraco from 8.2.0 to 8.6.3. After upgrade my nested control broken. All controls under nested control return 404
Like
/umbraco/textbox:1 Failed to load resource: the server responded with a status of 404 (Not Found)
/umbraco/mediapicker Failed to load resource: the server responded with a status of 404 (Not Found)
I faced same situation when I try to upgrade from Umbraco 7 to Umbraco 10 with custom backoffice view. The root cause of my case is the usage of no-longer-existing directive <umb-editor> in umbraco 7.
<umb-property property="property" ng-repeat="property in currentTab.properties">
<umb-editor model="property"></umb-editor>
</umb-property>
I fixed the case by replacing <umb-editor> directive with <umb-property-editor>
All controls return 404 inside nested control
Like
Provided those paths exist after the upgrade, the first thing I would check is permissions.
Thanks for your reply.
Folder permission is good.
I am not sure how nested content looking those controls in umbraco back office.
Working automatically. Nothing changed.
<umb-editor>in umbraco 7.I fixed the case by replacing
<umb-editor>directive with<umb-property-editor>is working on a reply...
