  • Nathan Reece 62 posts 376 karma points
    Jul 22, 2020 @ 06:31
    Nathan Reece
    How do I Install Bootstrap to my Umbraco 8 Project
    Whats the best way to install bootstrap onto my Umbraco 8 project?
    im not amazing at CSS and i have heard bootstrap can make styling my pages easier, the starter site seems to have some boot strap syntax but a lot is missing.
    Can anyone help me.
  • David Armitage 510 posts 2082 karma points
    Jul 22, 2020 @ 06:43
    David Armitage
    Hi Nathan,
    This is very easy as with any website.
    If you are using the starter site there should be a view called Master.cshtml or MasterView.cshtml.
    You are wanting to edit that file.
    First of all this link will help you. https://www.bootstrapcdn.com/
    1. At the top (in the html head) add a reference to bootstrap.css. The best way to do that is using a CDN link. You can grab the CDN link from by visiting the line I added above.
    It should look something like this.
    <link rel="stylesheet" href="https://stackpath.bootstrapcdn.com/bootstrap/4.5.0/css/bootstrap.min.css" integrity="sha384-9aIt2nRpC12Uk9gS9baDl411NQApFmC26EwAOH8WgZl5MYYxFfc+NcPb1dKGj7Sk" crossorigin="anonymous">
    1. At the bottom (just before the end body tag) add a reference to bootstrap.js. The best way to do that is using a CDN link. You can grab the CDN link from by visiting the line I added above.
    <script src="https://stackpath.bootstrapcdn.com/bootstrap/4.5.0/js/bootstrap.min.js" integrity="sha384-OgVRvuATP1z7JjHLkuOU7Xw704+h835Lr+6QL9UvYjZE3Ipu6Tp75j7Bh/kR0JKI" crossorigin="anonymous"></script>
    That's it. Very easy!
    Hope this helps.
    Regards
    David
    Jul 22, 2020 @ 06:53
    Nathan Reece
    Thankyou, That helped.
    I have wrote a Step by Step Blog if any one else needs help.
    https://www.umbrajobs.com/blog/posts/2020/july/how-to-install-bootstrap-with-umbrcao-8/
    Jul 22, 2020 @ 06:59
    David Armitage
    Yeah looks like you figured it out.
