What is the correct way to setup Umbraco back office on a load-balanced environment?
We set up like it's described in documentation - https://our.umbraco.com/documentation/getting-started/setup/server-setup/load-balancing/
Maybe some other recommendations?
Do not load balance back office, this is bad idea and bad practise, as you will finished with multiple source of true, save conflicts etc. You should have 2 enviroment: Backoffice (not load balanced) Frontend (can be loadbalanced)
Hey Arkadiusz,
Nice to see you here :) Thanks for your comment, I do not load balancing back office, we use the technique described here - https://our.umbraco.com/documentation/getting-started/setup/server-setup/load-balancing/
I'm thinking about how to make a class that will prevent the application from data corruption, like described here - https://our.umbraco.com/documentation/getting-started/setup/server-setup/load-balancing/flexible-advanced#explicit-master-scheduling-server
Thinking to check if it's a debug mode - then it's local environment, live servers defined by the host.
Thanks, Alex
Would this apply when using a CDN endpoint attached to storage blob media container or using an external firewall?
Umbraco in Load Balanced Environments
Hey Arkadiusz,
Thanks, Alex
