  • Damion 96 posts 331 karma points
    Jul 27, 2020 @ 10:59
    Damion
    Setting extended properties on a mocked IMember in Nunit
    I have a mocked the GetByEmail method to return a mocked IMember. The returned IMember is the basic IMember with no extended properties.
    To progress thought the test I have to be able to call SetValue on the IMember, as this happens in the code I am testing.
    So in the code I am testing I have
    var customMember = _memberService.GetByEmail(member.Email);
    And in the test I have
    _mockMemberService.Setup(x => x.GetByEmail(It.IsAny<string>())).Returns(new Member("test name", new MemberType(12)));
    Then in the code I set a value:
    customMember.SetValue("firstName", member.FirstName);
    But this crashes the test as there is no firstName property on IMember, although there is in the back office.
    How can I mock adding or setting these extended properties?
