  • mantach86 7 posts 27 karma points
    Jul 30, 2020 @ 13:12
    mantach86
    publish umbraco 8 website using visual studio 2017
    i'm trying to build an umbraco 8 website using visual studio 2017 it give me this error The type or namespace name 'Home' does not exist in the namespace 'Umbraco.Web.PublishedModels' (are you missing an assembly reference?) when I'm trying to open the pages and when I publish it , it give me error in w3wp.exe
    is there any solution for it ?
  • Paul Wright (suedeapple) 277 posts 704 karma points
    Jul 30, 2020 @ 13:55
    Try and get to the backoffice, and rebuild the Models.
    Jul 30, 2020 @ 13:59
    mantach86
    i tried many times this is my web.config , i think its configuration problem:<appSettings> <add key="Umbraco.Core.ConfigurationStatus" value="8.6.3" /> <add key="Umbraco.Core.ReservedUrls" value="" /> <add key="Umbraco.Core.ReservedPaths" value="" /> <add key="Umbraco.Core.Path" value="~/umbraco" /> <add key="Umbraco.Core.HideTopLevelNodeFromPath" value="true" /> <add key="Umbraco.Core.TimeOutInMinutes" value="20" /> <add key="Umbraco.Core.DefaultUILanguage" value="en-US" /> <add key="Umbraco.Core.UseHttps" value="false" /> <add key="ValidationSettings:UnobtrusiveValidationMode" value="None" /> <add key="webpages:Enabled" value="false" /> <add key="enableSimpleMembership" value="false" /> <add key="autoFormsAuthentication" value="false" /> <add key="dataAnnotations:dataTypeAttribute:disableRegEx" value="false" /> <add key="owin:appStartup" value="UmbracoDefaultOwinStartup" /> <add key="Umbraco.ModelsBuilder.Enable" value="true" /> <add key="Umbraco.ModelsBuilder.ModelsMode" value="AppData" /> </appSettings>
    Jul 30, 2020 @ 14:06
    What Models do you have in your "AppData" folder?
    Jul 30, 2020 @ 14:15
    mantach86
    Jul 30, 2020 @ 15:08
    See that OOD.FLAG file ??
    Says to me your Models are "Out Of Date"
    You will need to run the website, go the /umbraco backoffice, and re-run the ModelsBuilder
    Jul 30, 2020 @ 15:11
    mantach86
    how i can re-run the model builder ?
    Jul 30, 2020 @ 15:42
    Run the site using IIS, and login via the /umbraco/ URL
    Type in your Username/Password
    Re-run the Models Builder
    Jul 30, 2020 @ 17:26
    mantach86
    in models builder it show me this:
    The models factory is enabled.
    PureLive models are enabled.
    Models namespace is Umbraco.Web.PublishedModels.
    Tracking of out-of-date models is not enabled.
    Jul 30, 2020 @ 19:02
    You must have changed the Models Builder setting in WebConfig to "PureLive"
    Ensure you have it as...
    Then select to re-create Models
    You can then "REBUILD" your web project in VIsual Studio, and it should create the DLL you require.
    Jul 30, 2020 @ 19:16
    mantach86
    i tried on both visual studio 2017 and VS code and its not working it give me the same error is there any way to you see the code and help me ?
    Jul 30, 2020 @ 19:19
    Zip the code, and send to my email
    paul [AT] suedeapple dot co dot uk
    Jul 30, 2020 @ 20:37
    mantach86
    thank you paul i sent you all the details
