  • MB 273 posts 936 karma points
    Aug 01, 2020 @ 17:28
    MB
    Converting SFD > SQL > Syntax error when importing
    Dear everyone,
    I have a large sdf file (114mb) which I have imported into CompactView and exported as SQL.
    I create a new, empty database, opened a new query and pasted all the SQL inside but when I run it I get a lot of these errors:
    Msg 102, Level 15, State 1, Line 857175
    Incorrect syntax near ')'.
    Incorrect syntax near 'ACTION'.
    ALTER TABLE [cmsContentTypeAllowedContentType] ADD CONSTRAINT [FK_cmsContentTypeAllowedContentType_cmsContentType] FOREIGN KEY ([Id])
       REFERENCES [cmsContentType] () ON DELETE NO ACTION ON UPDATE NO ACTION;
    ALTER TABLE [cmsContentTypeAllowedContentType] ADD CONSTRAINT [FK_cmsContentTypeAllowedContentType_cmsContentType1] FOREIGN KEY ([AllowedId])
    ALTER TABLE [cmsContentVersion] ADD CONSTRAINT [FK_cmsContentVersion_cmsContent_nodeId] FOREIGN KEY ([ContentId])
       REFERENCES [cmsContent] () ON DELETE NO ACTION ON UPDATE NO ACTION;
    ALTER TABLE [cmsContentXml] ADD CONSTRAINT [FK_cmsContentXml_cmsContent_nodeId] FOREIGN KEY ([nodeId])
    The list continues with these empty parentheses. I don't know SQL so it's hard for me to track down the issue.
    Do I have to install Umbraco first in the empty database? I just want to switch from SDF to SQL.
    Thank you!
    Aug 04, 2020 @ 06:43
    Huw Reddick
    You may find it works better if you use the sqlcmd line to import the file rather than pasting it into a sql window. I've had problems in the past when just pasting large SQL files in the query windows.
    like below
    sqlcmd -S <server> -i C:\<your file here>.sql
    replace
    qlcmd -S <server>\instance -i C:\<your file here>.sql
  • Yakov Lebski 594 posts 2350 karma points
    Aug 08, 2020 @ 02:26
    Aug 08, 2020 @ 14:46
    MB
    This worked like a charm! I did however get a lot of SQL files but I used this command to combine them:
    copy /b *.sql combined-sql-database.sql
    Thanks for the help everone, it's much appreciated!
    // Mike
    Aug 08, 2020 @ 13:39
    Huw Reddick
    Yes, I used the same tool. What version of SQL are you importing it into?
    Did you try loading from the sql cmd line?
