  • Aspargeus 12 posts 102 karma points
    Aug 12, 2020 @ 13:32
    Aspargeus
    Using foreach in conjunction with Bootstrap rows and columns
    Hi.
    I'm pretty new to Umbraco and Razor.
    I have a bunch of client logos in my content in the backoffice, which I retrieve and display on the website using a foreach loop as such:
        var selection = Umbraco.Content(Guid.Parse("23b25f71-a1ae-45f7-906c-e410794dba0b"))
        .ChildrenOfType("client")
        .Where(x => x.IsVisible());
        foreach (var item in selection) {
    My problem is, that I'm using Bootstrap and want to display the first 4 logos with the class ".col-lg-3" inside a row and then start a new row with the next 4 logos and so on and so forth. So they all fit neatly in the Boostrap grid system.
    Is there any neat way of doing this?
  • Amir Khan 1289 posts 2746 karma points
    Aug 12, 2020 @ 20:13
    Amir Khan
    Basically a double foreach, the key part is ingroupsof, quick copy and paste from a blog loop, but this should point you in the right direction. There's some stuff in here related to pagination that you may not need:
    var i = 0;
    foreach(var newsItemRow in selection.OrderBy("PostDate desc").Skip((page -1)* pageSize).Take(pageSize).InGroupsOf(3)) {
    <div class="row">
        @foreach(var newsItem in newsItemRow) {
        <div class="post">@newsItem.Name</div>
    Aug 13, 2020 @ 10:43
    Aspargeus
    Awesome! Weeded out what I didn't need and it works perfectly!
    Thanks a bunch!
    Aug 13, 2020 @ 11:41
    Amir Khan
    No prob!
