  • Albion 7 posts 77 karma points
    Aug 14, 2020 @ 18:15
    Albion
    Best way to use Umbraco dictionary item value in Model class
    [Required(ErrorMessage = "test error message!")] public string TestVal { get; set; }
    Instead of using this static value "test error message!" what's the best way to use Umbraco dictionary item value in the model class?
  • Yakov Lebski 594 posts 2350 karma points
    Aug 17, 2020 @ 03:00
    Yakov Lebski
    You are welcome to use this package https://our.umbraco.com/packages/developer-tools/umbraco-dictionary-metadataprovider/ this is very easy way to add translation using naming convention in dictionary
    Aug 17, 2020 @ 14:55
    Albion
    Hi Yakov, enter image description here
    Thanks a lot for your reply. Managed to install the package.
    One more question: is there any way to have the full validation message using the dictionary item value instead of a combination of RequiredAttribute validation message and dictionary value?
    Eg: "The PropertyReference field is required." - this is the full validation message "PropertyReference" - gets from the dictionary value, but rest is default RequiredAttribute validation message
    Aug 18, 2020 @ 11:56
    Yakov Lebski
    You should manage it in this way
    your model for example ContactModel, has 2 properties Name, Email
    you should create in dictionary
    -Contact
    --Contact.Name
    --Contact.Email
    if you have attribues (for example Required) on you model
    --Contact.Name.Required
    for name convention properties you can create
    RequiredFormat: {0} is required InvalidFormat: {0} is invalid
    {0} this is name of property
    Aug 25, 2020 @ 14:32
    Albion
    Found another way to use dictionary item values as validation messages
    First step is, inside the model class use "IValidatableObject" interface to implement your own validation checks. For example, I'm using a simple null check.
    public class LoginModel:IValidatableObject
        [DisplayName("property ref number")]
        public string PropertyReference { get; set; }
        [DataType(DataType.Password)]
        [AllowHtml]
        public string Password { get; set; }
        public IEnumerable<ValidationResult> Validate(ValidationContext validationContext)
            if (string.IsNullOrWhiteSpace(PropertyReference))
                yield return new ValidationResult(UmbracoDictionary.GetDictionaryValue("Login.PropertyReference"));
            if (string.IsNullOrWhiteSpace(Password))
                yield return new ValidationResult(UmbracoDictionary.GetDictionaryValue("Login.Password"));
    Then create a separate class "UmbracoDictionary" which will allow you to access Umbraco dictionary items
    public class UmbracoDictionary
        private static UmbracoHelper _helper;
        private static UmbracoHelper Helper
            get
                if (_helper == null)
                    _helper = new UmbracoHelper();
                return _helper;
        public static string GetDictionaryValue(string resourceKey)
            string key = Helper.GetDictionaryValue(resourceKey);
            if (!string.IsNullOrEmpty(key))
                return key;
            return resourceKey;
    Finally, you can use ValidationSummary() inside your view page to display validation messages
    @Html.ValidationSummary()
    Aug 25, 2020 @ 18:03
    Yakov Lebski
    This is instesting way, but you need implement all validations by yourself.
