  • Nathan Reece 62 posts 376 karma points
    Aug 18, 2020 @ 09:01
    Nathan Reece
    Umbraco 8 Create content Programmatically after save and publish
    When i save and publish a document i want to be able to automatically add another document under there in code?
    Does anyone know how to go around doing that?
  • David Armitage 510 posts 2082 karma points
    Aug 18, 2020 @ 09:05
    David Armitage
    Hi Nathan,
    Umbraco events will be your best friend with this.
    https://our.umbraco.com/documentation/reference/events/ContentService-Events
    So what you need to do is create a published event and target the parent. The one you are saving and publishing.
    When the event fires you can then insert the doc type in code as usual.
    To create an event look at the documentation in the above link. To summarize though.
    1. Create a component for your published event
    2. Then create a composer to tell Umbraco about your event.
    Here is a copy of one of my published events. It doesn't do exactly what you need but it's half the way there.
    private void ContentService_Published(IContentService sender, ContentPublishedEventArgs args)
                try
                    foreach (var node in args.PublishedEntities)
                        if (node.ContentType.Alias == "customRedirectsFolder")
                            CustomRedirectsFolder customRedirectsFolder = _siteHelper.GetPageById(node.Id) as CustomRedirectsFolder;
                            if (customRedirectsFolder != null)
                                if(customRedirectsFolder.ImportCsvfile != null)
                                    _siteService.ImportCustomRedirects(node.Id, customRedirectsFolder.SkipRecords, customRedirectsFolder.TakeRecords, customRedirectsFolder.ImportCsvfile.Url);
                                    node.Properties["importCSVFile"].SetValue(null);
                                    sender.SaveAndPublish(node);
                                else if (customRedirectsFolder.ReRunDataFix)
                                    List<CustomRedirect> customRedirects = _siteHelper.GetCustomRedirectsNeedFixing(node.Id);
                                    if(customRedirects != null && customRedirects.Count() > 0)
                                        int count = 1;
                                        foreach(CustomRedirect customRedirect in customRedirects)
                                            _siteService.ImproveCustomRedirect(customRedirect);
                                            count += 1;
                                    node.Properties["reRunDataFix"].SetValue(false);
                catch (Exception e)
                    _logger.Error<PublishedEvent>("ContentService_Published | Exception: {0} | Message: {1}", e.InnerException != null ? e.InnerException.ToString() : "", e.Message != null ? e.Message.ToString() : "");
    Regards
    David
    Aug 18, 2020 @ 09:13
    Nathan Reece
    Thanks Dave,
    give I'll give that a try now.
    Aug 18, 2020 @ 09:31
    Nathan Reece
    Hey Dave,
    I'm still having some issues with it but i can see how this would work once I've got my head around it.
    Aug 18, 2020 @ 09:33
    David Armitage
    Yeah its tricky to begin with but once you have done one the rest are easy.
    I use events all the time for all sorts of stuff. They are very handy.
