  • Daniel Frear 1 post 71 karma points
    Aug 21, 2020 @ 10:43
    Daniel Frear
    White screen on backoffice - umbraco.css, Lazyload.js and others missing
    I've inherited an Umbraco site which was working OK a few days ago (in development mode run via VS2019).
    Having come back to it today I went to login to the backend (i.e. /umbraco) and was met with a white page. I've done some searching around and tried a few things:
    • Incremented the client dependency version and cleared ~/AppData/TEMP - no change
    • Copied over the original umbraco and umbraco_client folders from the archive provided (the one that worked previously) - no change
    • Double checked all the settings I can find - the only change I made was to point it to my dev SQL server
    • Cleared browser caches, tried incognito mode, tried a different browser altogether
    I'm at a loss as to what might be causing it, it's as if the mapping to the umbraco directory has somehow gone missing as I simply cannot access it when running the app
    Any help would be very much appreciated as I feel like I'm going round in circles
    Firefox console
    Network
    Regards, Daniel
  • Sven 34 posts 138 karma points
    Aug 04, 2022 @ 08:08
    Sven
    Hi !
    Did you find any solution for this problem? We're having the same issue. Regards, Sven
