  • Valentin Valeanu 29 posts 152 karma points
    Aug 28, 2020 @ 08:36
    Valentin Valeanu
    Macro and MVC forms in Umbraco 8
    Hello there,
    I am trying to make a MVC form as a macro. Even though it sees right in the back-end on the front-end it doesn't render itself correcly. Can someone help me?
    Here is how it looks on the back-end:
    back-end and here is how it looks on the front-end:
    front-end
    And below you can see the MacroPartialView:
    @model Umbraco.Model.ContactViewModel
    using (Html.BeginUmbracoForm<Umbraco.Controller.ContactController>("Submit"))
            <div>
                <p>
                    @Html.LabelFor(m => m.Name)
                    @Html.TextBoxFor(m => m.Name)
                    @Html.ValidationMessageFor(m => m.Name)
                </p>
            <div>
                <p>
                    @Html.LabelFor(m => m.Email)
                    @Html.TextBoxFor(m => m.Email)
                    @Html.ValidationMessageFor(m => m.Email)
                </p>
            <div>
                <p>
                    @Html.LabelFor(m => m.Message)
                    @Html.TextAreaFor(m => m.Message)
                    @Html.ValidationMessageFor(m => m.Message)
                </p>
            <input type="submit" value="Send" /> <input type="reset" value="Reset" />
            <p><div class="g-recaptcha" data-sitekey="6LexiiETAAAAAMcC8Fjj72f3MPJmgi3Kxmil8D8v"></div></p>
    Does anybody know what can be the issue here?
    Sep 03, 2020 @ 20:04
    Marc Goodson
    Hi Valentin
    My guess here is that a MacroPartial is a special kind of Partial View in Umbraco, it can receive Parameter values entered by editors when the Macro is inserted, and to achieve this it must @inherits a specific Model:
    But this then mucks up adding an MVC form like you are attempting here as you want the Model for this partial view to match your Form Fields eg
    But in a partial view you can only have one or the other!
    The workaround therefore is to create a new 'normal' Partial View in your Views/Partials folder, called something like RenderContactForm.cshtml
    Move your MVC form implementation into this Partial View with it's reference to your ContactViewModel at the top.
    If you only need to render your form in a template then you do not need to use a Macro at all, you can just write:
    @Html.Partial("/views/partials/RenderContactForm.cshtml", new ContactViewModel())
    But if you do need a Macro, eg so editors can choose to add the Form in the grid or Rich Text Area, then create a separate Macro Partial and make sure it has
    at the top...
    and then all that Macro Partial needs to do is render the normal MVC partial view eg:
    regards
    marc
    Sep 04, 2020 @ 09:28
    Valentin Valeanu
    Hi Marc, thank you for your reply.
    I have done exactly as you said but still the front end looks as before, it's seems like Html.BeginUmbracoForm doesn't generate a form tag, instead it generates a "umb-macro-holder".
    How can I make it work, should I import a library or something?
    front-end
    Sep 04, 2020 @ 15:23
    Marc Goodson
    Hi Valentin
    Which option did you go with?
    Calling the Html Partial directly from the template
    or calling the Html Partial from within the Macro Partial?
    regards
    Marc
    Sep 07, 2020 @ 07:00
    Valentin Valeanu
    Hi Marc, I chose to go with the second option, calling the HTML Partial from within the Macro Partial.
    Sep 07, 2020 @ 11:50
    Marc Goodson
    Hi Valentin
    That outter div with class umb-macro-holder is generated by the Macro Partial...
    is the issue not having an @ before the using statement, and so the template 'doesn't know' to write out the form in the template eg:
    @using (Html.BeginUmbracoForm<Umbraco.Controller.ContactController>("Submit")){
    make any difference for you?
    regards
    Marc
    Sep 08, 2020 @ 05:41
    Valentin Valeanu
    Hi Marc, it still doesn't work, this is how my MacroPartial looks like:
    @Html.Partial("~/Views/Partials/Contact.cshtml", new Umbraco.Models.ContactViewModel())
    And this is how Contact.cshtml looks like (the file that is referenced from the MacroPartial . You can see that now I added the @.
    @model Umbraco.Models.ContactViewModel
    @using (Html.BeginUmbracoForm<Umbraco.Controllers.ContactController>("Submit"))
        <div>
            <p>
            </p>
        <div>
            <p>
            </p>
        <div>
            <p>
            </p>
        <p>
        </p>
    On the front-end Umbraco still doesn't render a form while in the back-end the form looks as expected with all the text boxes vissible.
    Moreover, the text is underlined for some reason.
    Sep 08, 2020 @ 14:24
    Marc Goodson
    Hi Valentin
    I just had to try this out to confirm what might be going on!!
    I'm using 8.7RC
    I Create a Model:
    namespace Umbraco_8_7_RC.Models
        public class ContactViewModel
            public string Name { get; set; }
            public string Email { get; set; }
            public string Message { get; set; }
    and a Controller:
    namespace Umbraco_8_7_RC.Controllers
        public class ContactController : SurfaceController
            // GET: Contact
            public ActionResult Submit(ContactViewModel vm)
                return View();
    and a partial view:
    @inherits UmbracoViewPage<Umbraco_8_7_RC.Models.ContactViewModel>
    @using (Html.BeginUmbracoForm<Umbraco_8_7_RC.Controllers.ContactController>("Submit"))
        <div>
            <p>
            </p>
        <div>
            <p>
            </p>
        <div>
            <p>
            </p>
        <p>
        </p>
    and then a Macro Partial:
       @Html.Partial("~/Views/Partials/Contact.cshtml",new Umbraco_8_7_RC.Models.ContactViewModel())
    When I use either a grid or a rich text area, and choose to insert the contact form macro, and publish, then ...
    I get the form fields in the backoffice AND on the frontend...
    So you can see from my example, it's really similar to what you have!
    The only difference perhaps that I'm using @Inherits instead of @model at the top of the partial view? and that my models arent' coming from a namespace with the name 'Umbraco' - could that be conflicting?
    But sure is strange!
    Sep 10, 2020 @ 11:39
    Valentin Valeanu
    Hi again Marc,
    In the end I found out that it doesn't work only when I insert the macro in the RichTextEditor. If I insert the macro outside of the RichTextEditor then the macro renders on the front-end.
    Shouldn't it work both ways? I mean both in RTE and alone.
    Sep 10, 2020 @ 14:04
    Marc Goodson
    Hi Valentin
    In my example above, I'm inserting it in a Rich Text Editor, and I also tried in the Grid, and it works!
    I'm not sure what the difference is, I'm using V8.7RC, which version are you running?
    Does your versions now match what I have above?
    (It is strange and yes should work in both!)
    regards
    Marc
    Sep 15, 2020 @ 05:35
    Valentin Valeanu
    Hi again Marc
    Right now I am running Umbraco 8.6.4. Maybe I should try to upgrade it to V8.7?
    Now I have upgraded my website to V8.7, but I still have the same problem.
