  • Nikhil 54 posts 166 karma points
    Sep 16, 2020 @ 14:39
    Nikhil
    Umbraco 8: Two controllers with same method named Ping. The requested resource does not support http method 'GET'
    I have 2 controllers:
    1. AController : UmbracoApiController
    2. BController : UmbracoApiController
    Both have the same method:
    [HttpGet]
    public async Task<string> Ping()
    The first controller works i.e. https://localhost/umbraco/Api/A/Ping
    The second one https://localhost/umbraco/Api/B/Ping throws the error: The requested resource does not support http method 'GET'.
    Why does the second one not work?
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Sep 17, 2020 @ 05:48
    Marc Goodson
    101
    Hi Nikhil
    There are two implementations of HttpGet!!
    One for MVC Controllers in System.Web.Mvc.HttpGet and one for Web Api Controllers in System.Web.Http.HttpGet
    My guess is that in the controller that 'doesn't work' you've accidentally resolved [HttpGet] to come from the System.Web.Mvc namespace and not the System.Web.Http one...
    So have a look at the using statements in your controller that doesn't work to see if you have using System.Web.Mvc and revert it to be System.Web.Http to see if it works!
    or change
    [HttpGet] to be explicitly [System.Web.Http.HttpGet]
    to be super sure.
    regards
    Marc
    Sep 17, 2020 @ 08:54
    Nikhil
    Hi Marc,
    Yes the namespace was wrong. I changed it to
    using System.Web.Http;
    and marked the controller methods with
    Its working now. Thanks.
    Why have the same attribute in 2 namespaces?
    Nikhil
    Sep 17, 2020 @ 12:55
    Marc Goodson
    Just to annoy you? :-P
    It's because System.Web.MVC existed first and when they came to build the WebApi much later on they didn't want to make it wholly dependent on the System.Web.MVC namespace...
    ... or at least that's the explanation I remember.
    regards
    marc
