hi everybody im stuck and i am newbie, i got error while host my website
i published and create a database on host server but this show up
Source Error:
Stack Trace:
Umbraco.Web.Runtime.WebRuntime.Boot(IRegister register) in D:\a\1\s\src\Umbraco.Web\Runtime\WebRuntime.cs:55
[HttpException (0x80004005): Object reference not set to an instance of an object.]
System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +517
System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +185
System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +168
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +277
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +714
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.3650.0
i check documents permissions on plesk server its all full control, i contact my host they insist problem is about my config file , database i tried a couple of publish options and move my database but nothing work i am stuck.
Issue while publishing
Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] Umbraco.Web.Runtime.WebRuntime.Boot(IRegister register) in D:\a\1\s\src\Umbraco.Web\Runtime\WebRuntime.cs:55
[HttpException (0x80004005): Object reference not set to an instance of an object.] System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +517 System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +185 System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +168 System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +277 System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
[HttpException (0x80004005): Object reference not set to an instance of an object.] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +714
Hi Saltuk,
Make sure you have set correctly the read/write folder permissions.
Then try to enter your website/umbraco and see if it runs. If not, contact your hoster.
Hello Alex thank you for respond,
unfortunately /umbraco didnt work either
i am so newbie i did all files in httpdocs full control but not the httpdocs file
