  • Simon Brunemark 7 posts 86 karma points
    Sep 21, 2020 @ 08:51
    Simon Brunemark
    Static value will not be saved
    Hi.
    I have discovered an issue with the "Send form to a Url"-workflow in Umbraco Forms. When i'm trying to configure the field parameters with an "Static value" it will not save the value.
    I can map the field to a form value without problems. But when I type something in the "Static value" Umbraco lost the value (and remove the field itself) when I saved the form.
    This is how I configured the workflow: enter image description here
    And this is how it looks when I've saved the workflow: enter image description here
    I'm using Umbraco 8.6.3 with Umbraco Forms 8.5.3.
    Thanks in advance,
  • shinsuke nakayama 109 posts 250 karma points
    Dec 28, 2020 @ 02:43
    shinsuke nakayama
    I'm also having a same issue. It saves if you add new field afterword. However, the values doesn't get sent to the URL you specified.
    Umbraco 8.9.1 Umbraco form 8.5.4
