  • Nathan Reece 62 posts 376 karma points
    Sep 23, 2020 @ 05:02
    Nathan Reece
    How do I add bootstrap to my Umbraco 8 project?
    Hi Guys,
    So I'm working on a new project I'm Umbraco 8 and I want to add boot strap to make my coding and layouts that bit easier for me, Can anyone help me with where or how I would add this to my project?
  • David Armitage 510 posts 2082 karma points
    Sep 23, 2020 @ 05:05
    David Armitage
    Hi Nathan,
    This is done in the same say as all other websites. Nothing special here for Umbraco.
    You should have a master page inside the views folder. You should be adding your bootstrap styles and scripts in here. Either in the header or footer.
    You can pretty much follow the exact same instruction from the bootstrap website
    https://getbootstrap.com/docs/4.0/getting-started/download/
    Regards
    David
    Sep 23, 2020 @ 05:09
    Nathan Reece
    Thankyou
    Sep 23, 2020 @ 05:13
    David Armitage
    No problems.
