  • Adrian Ursu 20 posts 51 karma points
    Sep 26, 2020 @ 11:07
    Adrian Ursu
    Forum package for Umbraco 8
    Hi guys, Is there any stable forum package for Umbraco 8? I see that most Forum packages have not been maintained for a long time. Thank you in advance for any suggestions.
    Adrian
  • Dave Jonker 22 posts 72 karma points
    Dec 11, 2020 @ 10:36
    Dave Jonker
    Hi Adrian,
    Have you found one? I'm looking for one as well :-)
    Dave
  • Tom Brian Stegmann 25 posts 140 karma points
    Dec 29, 2020 @ 15:00
    Tom Brian Stegmann
    Hi Adrian and Dave,
    I am also looking for exactly that; a forum package that supports Umbraco 8.
    Can anyone from the community recommend a good package?
    Thank you in advance! 🙂
    Tom
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Dec 29, 2020 @ 16:59
    Huw Reddick
    There are none that I am aware of, there are a couple of very old ones but they do not work in version 8, not sure if the source is available but I would imagine it would be quite a big rewrite to get it working.
    You may be better off looking for a forum that can perhaps use the umbraco membership, or change the umbraco membership to use a forums membership provider and just integrate them that way.
    Dec 30, 2020 @ 13:51
    Tom Brian Stegmann
    Hi Huw,
    Thank you for your input. 🙂
    Yes, the older packages have not been updated for ages, so I do not trust them in terms of Umbraco 8 compatibility or future scalability.
    I am tempted to resolve the situation by creating a reusable Forum solution based upon the Umbraco Membership foundation.
    Tom
    Dec 30, 2020 @ 17:02
    Huw Reddick
    If you need a starting point, although this is old and not compatible with v8, I have been able to work out most of what was done using a combination of the files and the package.xml to extrapolate what document types were created for it etc.
    I have currently got most of it working to a degree :)
    If I get chance to finish the upgrade of it to v8 I will try and repackage it all.
    Forum thread
    Jan 01, 2021 @ 22:30
    Huw Reddick
    2
    I have almost completed rewriting the Simpily Forum package to work in v8, had to do quite a bit of rework in the backend stuff so need to do a bit more testing, but should be finished in a few days hopefully.
    Jan 04, 2021 @ 17:24
    Tom Brian Stegmann
    Very interesting - I am looking forward to seeing the finalized 'version 1.0'. 🙂
    Jan 03, 2021 @ 18:59
    Huw Reddick
    2
    If anyone wants to see it in action, I have a test site up at Forum for Umbraco
    You should be able to register to make posts. I am currently testing the package install so should be able to release it soon.
    Any comments/observations welcome.
  • Rodolphe Toots 35 posts 166 karma points
    Jan 03, 2021 @ 23:15
    Rodolphe Toots
    I tried to register, but got password validation error.
  • Ben Haigh 1 post 71 karma points
    Jan 12, 2021 @ 12:36
    Ben Haigh
    This is looking good, I was about to start having to build a forum soon, just wondering if you are willing to share yet?
  • Andy Boot 50 posts 193 karma points MVP 2x
    Feb 05, 2021 @ 08:53
    Andy Boot
    Hi there,
    Please excuse the out of the blue reply to this thread, but I was looking for a forum plugin for Umbraco 8 and came across your posts showing some of the impressive work you've done. I don't suppose you've managed to get anything together for a release? I would be very interested in trying it!
    Many Thanks,
    Andy
    Feb 05, 2021 @ 10:10
    Huw Reddick
    2
    Hi there, I am getting close, just working on an issue which I think relates to multi language sites, hopefully I will get chance to look into that problem over the weekend.
    Did you try registering on my test site? if so and you would like to test the package install I can drop you an email.
    Feb 05, 2021 @ 10:26
    Andy Boot
    Hi there, thanks for getting back to me so soon. I'd love to give it a test! I've just registered, created a new thread and comment and looks to work flawlessly. Good work!
    Feb 05, 2021 @ 14:33
    Huw Reddick
    Thanks for giving it a try, I will drop you an email later today/tomorrow (bit swamped at work today, typical Friday :D )
    Feb 05, 2021 @ 14:39
    Andy Boot
    Ah that's great thanks, honestly take your time! 🙂
    Have a great weekend!
    Jan 03, 2021 @ 23:31
    Huw Reddick
    try a longer password, I think the only restriction is length which is 10 by default in Umbraco
    Jan 12, 2021 @ 16:25
    Rodolphe Toots
    ok, worked with longer password.
    Jan 12, 2021 @ 17:46
    Huw Reddick
    did you receive the validation email after registering?
  • kate br 2 posts 71 karma points
    Feb 05, 2021 @ 15:03
    kate br
    I had the same experience
    Feb 05, 2021 @ 17:29
    Huw Reddick
    What experience would that be?
    Feb 06, 2021 @ 12:03
    Huw Reddick
    2
    Just ironing out a couple of small issues so hopefully will put a release together soon.
    Feb 12, 2021 @ 16:53
  • Alejandro Ocampo 67 posts 330 karma points c-trib
    Feb 21, 2021 @ 15:19
    Alejandro Ocampo
    Hi Huw,
    it looks like the repo is private, any chance you make it public to have a looksy?
    Thanks!
    Feb 21, 2021 @ 17:36
    Huw Reddick
    Done, sorry about that I thought I had already made it public :)
    Alejandro Ocampo
    Thanks!
  • Abdo Abdulrehman 1 post 21 karma points
    Feb 28, 2021 @ 01:14
    Abdo Abdulrehman
    Great work Huw, I just managed to get it running locally and tested couple of items and what I see so far is working.
    Just couple of feedback from initial view. You seem to be missing master.cshtml file When initially I have set this up I didn't have smtp configured and there were no errors to indicate something went wrong or no current way to request an email to be resent/forgot password.
    Are you planning to add further features to this package?
    Feb 28, 2021 @ 07:19
    Huw Reddick
    Some instructions needed :)
    Master.cshtml ref is meant to be replaced with whatever the master template for your site is.
    I am working on a search at the moment and will then probably look at moving the posts into a custom table rather than using umbraco content. Jus a little busy at work currently.
  • Mike Welch 8 posts 76 karma points
    Mar 18, 2021 @ 18:38
    Mike Welch
    I tried to register, but I did not receive the email to verify my email address.
    Thanks Huw!
    -Mike
    Mar 18, 2021 @ 18:43
    Huw Reddick
    I'll take a look later, I was making some changes to my test site last week so could have broken something :)
    Mar 18, 2021 @ 19:57
    Huw Reddick
    Hi Mike,
    I manually approved your registration. There was an issue with my mail settings so the email didn't get sent.
    I should probably add a resend email option :)
    Mar 18, 2021 @ 20:01
    Huw Reddick
    I should mention that the version on my test site has the search and paging which is not in the package currently available. I should hopefully be releasing the update at the weekend all being well.
  • Aleatha Carr 2 posts 73 karma points
    Mar 26, 2021 @ 21:05
    Aleatha Carr
    I didn't receive the email to verify my email address. Thanks!
  • Brendan Rice 538 posts 1102 karma points
    Mar 26, 2021 @ 22:45
    Brendan Rice
    Hi Aleatha,
    it seems like the package uses the standard SMTP settings from the web.config.
    Have you changed the config so that it is valid?
    If you're working locally you can use Smtp4Dev to test.
    Mar 27, 2021 @ 07:24
    Huw Reddick
    The email was sent successfully and according to my mail server logs it was delivered ok so you may want to check any spam/junk folders you have.
    Mar 27, 2021 @ 07:25
    Huw Reddick
    Email is setup correctly and the email was sent and delivered by the mail server
  • Tom 1 post 71 karma points
    Feb 18, 2022 @ 10:12
    Tom
    Hi Huw, Do you have any plans to make it work with V9? thanks, Tom
    Feb 18, 2022 @ 16:37
    Huw Reddick
    Hi Tom,
    I am looking at it yes, although it may be some time as work fairly busy, but have made a start.
  • Steve Rooke 3 posts 73 karma points
    Dec 06, 2022 @ 17:04
    Steve Rooke
    Hi Huw
    I suppose the next question is, have you done any work on this to bring it up to Umbraco 10? thanks, Steve
    Dec 06, 2022 @ 19:55
    Huw Reddick
    Yes, check the new umbraca market place and search for mediawiz but if you wait a couple of days I will be posting an update
    Dec 07, 2022 @ 08:56
    Steve Rooke
    Excellent Huw. Thank you!
    Dec 07, 2022 @ 09:37
    Huw Reddick
    It may be longer than a couple of days before next update as trying to get it to work with v11 but my package migration is throwing an error in 11
    Dec 07, 2022 @ 10:10
    Steve Rooke
    No worries - not urgent. I had a client feature request for some time in the future. Thanks for your help.
    Dec 07, 2022 @ 11:29
    Huw Reddick
    I'm not sure If I will be continuing with it beyond Umbraco 10 as trying to figure out how to get everything installed in 11 is just driving me nuts and really don't have the free time to try and figure it all out (nuget packages are a PITA), so I will finish the changes I was planning for version 10 and hopefully post an update early next week.
    Dec 08, 2022 @ 15:17
    Huw Reddick
    Just posted a new nugget package which should work for both Umbraco 10 and 11
