  • Thomas 319 posts 606 karma points c-trib
    Sep 29, 2020 @ 08:52
    Thomas
    Custom section - reuse rte - set no -dirty to model
    Hey
    I have some trouble in a custom section that I have build.
    I'm reusing to rte from Umbraco with this.
    <umb-property-editor model="rte" no-dirty-check></umb-property-editor>
    <a class="btn btn-primary" ng-click="saveComment()">Save</a>
    $scope.rte = {
        view: 'rte',
        value: "",
        config: {
            editor: {
                toolbar: ["code", "undo", "redo", "bold", "italic", "bullist"]
    And that gives me
    When I type in text I would like to prevent the "do you wanna save your changes" modal that pops up when an editor leaves the page..
    I have tried with "no-dirty" on the umb-property-editor put that didn't do the trick... Is there away to get that ?
    Sep 30, 2020 @ 20:16
    Thomas
    Anyone ??
    Sep 30, 2020 @ 20:54
    Marc Goodson
    Hi Thomas
    Is it
    no-dirty-check
    that you are after?
    instead of
    no-dirty
    regards
    Marc
    Sep 30, 2020 @ 20:58
    Thomas
    Mistyping... did use no-dirty-check... :)
    Still not working, asking for the editor to save changes
    Oct 01, 2020 @ 06:05
    Marc Goodson
    Sorry Thomas
    was just skimming :-( and noticed the difference in the title, apologies.
    no-dirty-check directive will work if you place it on the actual
    I'm not super sure if you are using the umb property editor directive wrapper around the rte property editor how you would do that - I can't see a way in the source code of applying a similar rule to prevent dirtyness from being checked.
    https://github.com/umbraco/Umbraco-CMS/blob/5ce9a3e74f3b8470430298db5f00e4212b95619e/src/Umbraco.Web.UI.Client/src/common/directives/components/property/umbpropertyeditor.directive.js
    I did see this forum post
    https://our.umbraco.com/forum/umbraco-8/98277-how-to-stop-you-have-unsaved-changes-message
    and the suggestion to set the form as being pristine when it's saved?
    regards
    Marc
    Oct 01, 2020 @ 06:59
    Thomas
    Thanks for your reply :)
    I have tried
    var currForm = angularHelper.getCurrentForm($scope);
    currForm.$setPristine();
    but currForm are alway null...
    Oct 01, 2020 @ 07:27
    Thomas
    I could just save the node when then post a comment.
    with this:
    contentResource.getById(editorState.current.id)
            .then(function (content) {
                console.log(content)
                contentResource.save(content, false, [], true)
                    .then(function (node) {
                        alert("Retrieved, updated and saved again");
    But getting this error:
    {"errorMsg":"An error occurred","data":{"Message":"No variants flagged for saving"},"status":404}
    Oct 01, 2020 @ 07:37
    Thomas
    Need to add content.variants[0].save = true;
    Oct 01, 2020 @ 07:38
    Thomas
    Hmm but the Unsaved changes modal are still coming. But the page saved succesfully.. strange...
    Oct 01, 2020 @ 07:58
    Marc Goodson
    The Unsaved changes modal only appears if the form is 'dirty'...
    if you are working in a custom dashboard, then saving the item won't know to mark your form undirty
    if you look in dev tools, you'll see the dirty class appear on your form entry when you start editing in the field, and see that it remains even when you save.
    setPristine(); is probably the correct thing to do here
    but it's getting a reference to your dashboard form that appears to be the challenge!
    There is an example from a post, referenced from the other forum post:
    var contentForm = angular.element('form[name=contentForm]').scope().contentForm;
    would that approach get you your form and allow you to call setPristine(); ?
    regards
    Marc
    Oct 01, 2020 @ 08:51
    Thomas
    I can see the form gets the class ng-dirty :)
    Yes can't catch the form...
    This
    is just giving med this.. Cannot read property 'contentForm' of undefined
    Gives me Undefined...
    angular.element('form[name=commentForm]').scope()
    Oct 01, 2020 @ 18:59
    Marc Goodson
    Yes it will need to be the name of your form? presume that is commentForm?
    https://docs.angularjs.org/api/ng/function/angular.element
    but I'm not sure why it's not finding it or if it is finding it, why .scope is undefined... frustrating because I reckon calling setPristine would get rid of the ng-dirty css class and then the un saved changes dialog wouldn't be triggered...
    Oct 02, 2020 @ 07:02
    Thomas
    Can get the element with angular.element('ng-form[name=commentForm]') but the .scope() still gives an undefined...
