  • Caglar Tasci 19 posts 125 karma points
    Oct 12, 2020 @ 14:53
    Caglar Tasci
    Routing Problem with multilingual setup
    i have an umbraco 7.6.4 instance with multiple root nodes. i also added 2 languages to the Language setting. German and English. enter image description here Everything works until i try to open the 3rd Node Level which is a list item in my case. enter image description here I get the Error "No physical template file was found for template bloglist". enter image description here Bloglist is in Fact my 2th Level. So it seems that the routing runs false, believing to be in the 2 level instead of the 3rd, where it should.
    I also tried to turn the "umbracoHideTopLevelNodeFromPath" to false and true. enter image description here
    What i am doing wrong ? Thank you in advance for the support.
    Oct 19, 2020 @ 14:19
    Caglar Tasci
    Nobody ?
