  • Richard 3 posts 74 karma points
    Oct 20, 2020 @ 11:25
    Richard
    Umbraco Azure Blob CDN - cache issue
    I've followed the guide at https://our.umbraco.com/Documentation/Extending/FileSystemProviders/Azure-Blob-Storage/index-v7 to implement an Azure blog CDN to host the media files. The implementation is working in that the existing /media url is now redirecting images to load from the cache CDN instead. I do however seem to be experiencing two issues:
    1. If i update an image in the back office to one with exactly the same name it still redirects to the existing image in the cache container. If i manually go to the file on the media container i can however see it has updated. Is there as such a way to force the redirect to link to the new cached image?
    2. Non images (such as a PDF) do not redirect to use the CDN. Is there a way around this?
    If I can resolve issue 1, I'd also be looking to avoid the redirect if possible so that I can have the CDN image URL directly in the HTML rather than a link to /media that then redirect. Will this be possible?
  • Angel 45 posts 101 karma points
    1 week ago
    Angel
    Hi Richard,
    I was wondering if you have figured out a fix to this issue? I am using Umbraco 8.18.9 and experiencing the same problem.
    -I update a PDF file in the back office with one that has changed but has the same file name. -When I re- select the PDF file through media picker on a page (which I believe I shouldnt need to do), the file that is served up when a user clicks on the link is the old version of the file. -Clicking on the link to the PDF from the Media Section of the back office loads up the OLD version of the file as well.
    Any thoughts?
