  • bh 444 posts 1544 karma points
    Oct 21, 2020 @ 14:37
    bh
    Partial inside a foreach
    On my docType I have a nestedcontent. The type of that nested content is NcHeroShadowBox.
    @foreach(NcHeroShadowBox pillar in Model.GetPropertyValue<IEnumerable<IPublishedContent>>("diversityPillars")) {
        @Html.Partial("ncHeroShadowBox", pillar);
    I'm getting this error on the code above:
    Cannot bind source type NcHeroShadowBox to model type System.Collections.Generic.IEnumerable
    Oct 21, 2020 @ 15:10
    Lee Kelleher
    Hi bh,
    The issue is to do with casting the pillar object to the type that the partial view is expecting. (Depending on your understanding of C# that will either sound fine, or a bit confusing.)
    Either way, in your "ncHeroShadowBox.cshtml" partial-view file, it should start with the line...
    @inherits UmbracoViewPage<...>
    The bit in the angle brackets is the object-type for that this partial-view expects to use as it's @Model. Looking at your error, it appears to start with IEnumerable<...>.
    If you swap that to be...
    @inherits UmbracoViewPage<NcHeroShadowBox>
    ...then hopefully that should solve it.
    - Lee
